Question about Toro Lawn Mower With Toro Power Tools
Toro self propelled 22 inch recycler lawn mower won't self propel
I was mowing the lawn and the self propel just stopped working. I'm told this could be an easy fix, but of course there's nothing in the instruction manual. Any ideas?
  • dorkyy Jan 28, 2009
    Thank you very much for suggestions. It is dead of winter so I haven't been able to try these suggestions. I will try once spring arrives. Thank you very much.
  • Anonymous May 14, 2009
    Toro 22" Recycler with self propel but self propel is not working or only barely. Not any help up a small grade.. Are there any simple adjustments to make?
2 Suggested Answers
SOURCE: toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
Posted on Jun 08, 2009
Why do the wheels lock up on my self propelled 22" recycling mower
Sounds like they need cleaning & oiling. Check that nothing is keeping it from moving. I have ran over string or cord before & got caught and wrapped around wheel.
Oct 27, 2014 | Toro 22 in. Personal Pace with Blade Stop...
Why won't my 22 in. Kohler Low Wheel Variable Speed Self-Propelled Gas Lawn Mower self propel anymore?
i would guess that the belt is'nt tight enough when engaged. when you press the drive bar on the handle it should make the belt really tight if not it will need replaced. sometimes the gears in the wheels will mess up. there are videos on you tube that describe that and also the belt.
Apr 22, 2017 | Garden
Toro recycler self propelled 6.5hp, 22" (gts) 2010
Hi Wahid
You probably sheard the flywheel key...
You will need to pull the flywheel off and replace the sheard key to be able to start the motor again.
Please take time to rate me
Bud
Mar 18, 2013 | Toro Garden
Toro self propelled 22 inch recycler lawn mower not picking up grass
is there to much old grass built up under the mower?did you damages the blades
Apr 06, 2012 | Toro Power Lawn Mower
How do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under.
how do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under
Aug 27, 2010 | Toro Lawn Mower With Toro Power Tools
I have a 22 in Recycler Lawn Mower. I haven't had it 1 year yet. It is supposed to be self propelled but that quit being self propelled today. thank you in advance donna
turn it over and check the drive belt. it's probably too loose or broken. don't ask me how to fix it, i'm here trying to find out why mine keeps dying.
May 19, 2010 | Toro Lawn Mower With Toro Power Tools
Toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
Good luck.
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Quit self propeling stopped suddenly while mowing
Probably needs a new belt. this happens when you use it alot!!
Apr 11, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
4,974 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
