Question about JVC KD-S6060 CD Player
BMW installation Here's a good one. I wire the unit up and it all works just fine. As soon as touch any button such as the tuner, all the sound goes off (power stays on). If i disconnect the speakers, then connect them again, it works again. This is fitted into an old '94 BMW 316 and the wiring colours bear no relationship at all to those in the workshop manual.
  • 27 Answers
When in doubt, run wire. Run new wire to each speaker from the amp. Alternatly, behind the radio cut one speaker wire and test, rehook and cut the next wire and test. When you cut off the affected speaker the system will work and you will know which one to rewire or replace.
Posted on Dec 18, 2008
حضرة السيد ابراهيم ابو شرخ سوف نهديك هذه الرسالة عن تطور تكنولوجيا
Posted on Nov 03, 2008
Hcd-eh15
The laser pickup assembly has a short causing the unit to shut down, The whole assembly would need to be replaced in order to resolve, not worth the cost to repair, cheaper to replace.
Apr 25, 2012 | Sony Audio Players & Recorders
Hi i recently bought a Takamine EG 260c G Series acoustic electric Guitar with TP-4T preamp installed in it. Now the problem is when i connect my guitar to an amplifier, the sound comes through it only...
That is working backwards from what it should be. I suspect a wiring error. Since this is a recent purchase, do NOT risk voiding your warranty. There isn't any real good documentation on the tuner.
I am not sure which tuner you have HOWEVER with one type, the FIRST press will turn on the tuner with the sound going out as well till the tuner goes off. The SECOND press silences the sound and is tuner only, the THIRD press turns off tuner and passes the sound. This is different than a lot of tuners and you will need to do three presses to restore sound instead of the usual two.
May 02, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
I bought a RAV DVD2 player from a garage sale for $10.00. The seller said it worked fine and they took it out of their BMW for another unit that had a touch screen. I want to make sure it works before I...
you can take the yellow and red wire on deck clip and the brain clip together then do the same to the neg. black wires and hook all the of cords from uint to a 12 volt batt and press the power button
Feb 20, 2011 | Rockford Fosgate RAVDVD2 Car DVD Player
I have a cms1 clarion unit. The tuner portion quit working but the rest still works fine. The tuner is stuck on one frequency and will not change or tune to other freqs, also there is no sound coming out....
The tuner portion is in the head unit, and sounds like non-repairable problem. If you decide to sell please let me know, I destroyed my amp box of my CMS1 cutting it up to fit inside my motorcycle.
Mar 30, 2010 | Clarion CMS1
Vrv785bt- No sound except tuner
sounds like u have a premium sound system. what u need to do is take ur blue/white remotewire to ur blue power antennat that should activate ur factory amp.
Apr 16, 2009 | Clarion VRX785BT Car DVD Player
Kenwood kdc-x592 No sound on CD and..
your amp turn on is hooked to the power antenna wire. Swap the blue wires and youll be good to go. Since the power antenna is not needed, when the radio goes off tuner, the 12V signal is turned off. and your amplifier will also then lose its remote turn on.
Reverse the 2 blue wires.
Dec 28, 2008 | Kenwood KDC-X590 CD Player
No Sound
go to standby hold m-log button tell menu comes on display press up on volume control tell amplifier comes on display pess left on volume control tell display says amp on. the built in amp on the stereo turns of and on to provide better sound quality to the pre-amp out puts
Oct 03, 2008 | Kenwood KDC-X590 CD Player
AVIC-Z1 options just quit
It actually sounds like you don't have your parking break wire (light green wire on wireing harness) grounded. I have an 06 F150 and the same thing happened to me when I instaled it. I had no address search and some other functions didn't work as well. Try to locate the light green wire and ground that to anything metal. Hope this helps, the install manual isn't very good at describing this.
Aug 11, 2008 | Pioneer AVIC-Z1 Car DVD Player
Hp z558
This sounds like a poor put together pc. If the DVD drive does not eject then either the dvd is faulty or the IDE cable and/or IDE1 connector on motherboard is not installed, try ejecting through my computer(right click on drive then Eject), if this works the button is faulty. The same goes for the TV Tuner card, again possibly a corrupt or non installed driver, try re installing mother board drivers and card drivers. This really needs to be returned as the pc is not fit for it's use.
Feb 19, 2007 | HP z558 (EG652AA) PC Desktop
No Sound
most ram trucks came with a infinity system. the amps are in the front doors, mounted to the 6x9 speakers. and they power the tweeters in the columms, and also rear speakers if you have them. I had to replace the entire system.
Aug 23, 2006 | Pioneer DEH-P47DH CD Player
JVC KD-S6060 CD Player Logo
105 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
