Question about Ricoh Aficio 2015 Copier
Feeder and glass product offset copies
When we send a document to the printer from a computer it works great. But if we take that same piece of paper and run it through the top feeder or place it on the glass then the result is an offset document. It seems to shift the document over and up about 1/4". Did something get moved on the inside?
  • michaelsteed Nov 04, 2008
    thanks for the response, but how do I know what the initial position of the mirrors should be, is it marked somehow. Are the mirrors under the glass, so I need to remove the glass?
  • 24 Answers
Check if the mirors are fixed and if not, bring them to the initial position! it's possible you should make an immage adjustement because teh scanner moved from the innitial position!
Posted on Nov 03, 2008
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
How do I clean document feeder? It is putting
If it is just puting lines on the copies ONLY when using the feeder here is all you need to do to clean that thoroughly.
Get a phillips screw driver. Lift the document feeder, you will see the "seal glass" about 1 inch wide on the left side. Remove the 2 silver screws, One on each end. Lift that glass up and out. Lay it on a white piece of paper. Take some alcohol and a regular piece of copy paper and clean that until you see nothing on that glass by placing it against the white paper. Get every little speck off. Then put the glass back in.
If you want to clean the entire scanner that is a different procedure all together. Let me know .
Feb 10, 2010 | Xerox WorkCentre M20i All-In-One Laser...
It works great in all aspects, but when I make a copy of something there is a black line about 2.5" from right side of paper (only when I use the auto feeder to copy) If I lift the lid and palce the paper...
You need to lift the document feeder and clean the small **** exposure glass located to the left of the main exposure glass.Any foreign substance on this glass(ink, glue, correction fluid,etc.)will cause lines on copies when you use the feeder.
Oct 08, 2009 | Samsung SCX-4725FN All-In-One Laser...
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Copies run through feeder distorted
Document feeder Paper feed rollers should be cleaned with alcohol, blow out the document feed area with compressed air (computer duster), check feeder for bits of paper, post it notes, and signature flags. Clean glass, check for sticky areas on the glass.
Hope this is of some help.
Ed
May 12, 2009 | Toshiba E-Studio 3511 Color Copier
Lines on my copies
As the page you wish to copy goes through the document feeder, it passes the scanner as well as a white plastic band that the scanner "compares" the dark writing or data on the page to. If this white plastic band is not very clean, the scanner reads the dirt as if it is part of the image you are scanning. Try cleaning the band as thoroughly as possible, as well as the small piece of glass to the left of the larger glass on the flat bed scanner. Make another copy to test your results.
Hope this helps!
May 07, 2009 | HP LaserJet M5025 MFP All-In-One Printer
Lines of copies utilizing automatic feeder
look to the side of your big glass and you'll see a piece of glass about 1.5" wide. thats the galss that is used for scanning from the feeder. theres got to be something on that glass. possibly white-out or even a small speck of toner can cause that. look closely.
hth,
razors
Mar 16, 2009 | Brother MFC-9440CN Laser Printer
Line when coping from document feeder
If you lift the document feeder, you will see a narrow piece of glass on the left side. Originals are scanned across this when the feeder is used, so a small speck of dirt becomes a line when copying. clean the glass, and it should be good to go.
Feb 17, 2009 | Ricoh Aficio SP-C210SF Printer
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
Document Feed
first u switch off and switch on the machine, that time ur document feeder get rotating its not feeder problem. otherwise pls u check ur feeder driveres.
Jul 23, 2008 | Office Equipment & Supplies
Ricoh Aficio 2015 Copier Logo
59 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
