Question about Gateway (4000474) Motherboard
Gateway 503gr power switch
I discovered that the power button was broken. I took the front panel off and saw that one of the plastic pieces that holds the switch in place is broken. But with the front panel off, when I press the power button, it still won't power up. Gateway says I need to order a power switch and they gave me the phone number of a company. This company only has the front panel, not the power switch. I don't think this will help me.
    Scholar:
  • 172 Answers
If you are a practical person, the power on switch is the crudest item ever on a pc. The switch simply completes a circuit. If you look on you motherboard at the front panel connector cables, you will see the two that go to the power on switch. remove them, flash a small screw driver across the terminals and it will come to life
Posted on Nov 15, 2008
Lost power button got turn off
try this; carefully detach (pull off) the front panel of the base tower unit.. and behind the plastic front that you just took off there's a little button that you can push to power off and on. The power button just goes through the plastic cover and pushes the button.
Jan 04, 2016 | Gateway Computers & Internet
Power button broke gfdn240el1ww
There are two main pieces to the front panel for the GFDN240EL1WW dryer-- the plastic panel and the circuit board. The actual replacement part is: Control Panel WE19M1687. The panel can be purchased for from places like partselect.com or repairclinic.com or Amazon or even EBay, etc. for $100-$200+.
The power button is just a piece of plastic mounted to another piece of plastic; it is not electronic. When pushed, it presses against the circuit board, which then turns the unit on/off. When the power button breaks, it typically means the little plastic button has broken off from the plastic panel. Most likely, the problem is the mount point for the button and the button is actually re-usable.
A cheaper quick-fix is to:
  • Remove top screw from back of the front panel
  • Remove main front knob from the panel
  • Remove screw from behind the front knob
  • Grab both sides of the front panel and push/pull up to remove the panel
  • Disconnect the block connector (power) from the circuit board after removing the panel
  • Locate the power button and mounting position
  • Inspect to see if it looks like you can glue the button back into place
  • Buy a small tube of loctite Stik'n Seal Ultra Universal Adhesive
  • Put some Stik'n Seal on the button mounting point for the power button (be generous)
  • Press the button onto the mounting point and hold for a few minutes
  • Add more Stik'n Seal around the edges of the mounting point and the button mount after you have held the button in place long enough so that it sticks
  • Let the whole thing dry for several hours (instructions on the adhesive say 24hrs
  • If you are worried about the button staying seated while the adhesive sets, you can always try tape it into place
  • When dry, replace the front panel by reversing the steps above used to remove the panel: connect the power block, slide the panel back into place, replace the front screw and knob, replace the top screw in the back of the panel
Jan 23, 2013 | GE DBVH512GFWW Dryer
My gateway 503gr will not power on when you press the power button has power to mother board every thing is plugged in there is a green light on the power supply and the mother board and the power switch...
This could have a bad power supply (in this case I would try a new one just in case).
All other things being normal, I would guess a bad motherboard.
The best thing to do is disconnect everything but the CPU and memory and try to start it.
If it starts, then start connecting stuff until it doesn't start--this will tell you what is bad.
Apr 13, 2011 | Gateway 503GR PC Desktop
Double sided printing - 1st side, no problem 2nd side - instructions said to push down orange button. Button does not release - both green and red lights are blinking - does not print. I have gone...
I have the same problem as the original poster in that the orange button goes down when pressed but then slips just a little to the side and won't come back up.
I've made it come up by pounding on the case next to the button with my fist, by jiggling the button with the eraser end of a pencil (usually resulting in it ruining the printing of the booklet I am trying to print by printing a test page), by grasping the side of the top casing near the button and trying to flex it, and by using a pocket knife to try to make the button's hole bigger in the casing. It finally got so bad that nothing I would do would make the button work.
So I took the top off and found out that the "orange button" has an offset part that is what actually contacts the switch, and that the orange plastic part is mounted in a clear plastic piece which also acts as the lens portion for the red and green lights. The clear plastic piece is attached to the cover with two screws.
Over time, the clear plastic piece had broken in half, allowing the part holding the orange button to swivel. This initially was what would cause the button to get hung up under the hole and not able to come back up, and eventually through all my efforts to make it come up it moved the portion of the orange button that contacts the actual switch far enough that it no longer would make contact.
Three possible fixes: 1. Order a new clear plastic piece from Samsung. 2. Glue the clear plastic piece back together and hope it holds. 3. Go the ugly but sure route of removing the broken part of the clear plastic piece along with the orange button and spring, and cut the top open between the button hole and the edge so that the actual switch can be reached.
I chose number 3: This will void your warranty, but mine was way out of warranty anyway.
First, I turned the printer off and unplugged the power cord.
I took off the top, by opening the front panel of the printer where the toner cartridge is installed, then removing the two screws that hold the front of the top down. Then it was a matter of daring to break the plastic of the top panel in freeing the plastic tabs so that the panel could be removed.
I found that by lifting the front until the side tabs gave way and then removing the hinged cover where the paper comes out, I was able to finagle the top off without damaging anything. It probably would be easier to remove by taking the screws out of the black rear cover and so forth, but this worked.
Next, with the cover removed and turned upside down, I removed the screw holding the broken portion of the clear plastic piece and removed it along with the orange button and spring. I left the other half in place so that it would transmit the light properly for the red and green lights.
Then, taking my trusty Leatherman tool, I used the saw blade to open up the area between the button hole and the outside edge of the top. I used the Leatherman's file to smooth off the rough edges.
Next, I reassembled the printer (this was probably the hardest part - and at this point is when I realized that taking the back off would maybe make things easier, but if you aren't afraid to torque the plastic a bit it will all snap back into place), plugged it back in and fired it up.
I printed a test booklet. First side printed normally, the red light came on as it should. I removed the paper and reinserted it, then used a pencil to reach in and press the switch. Success! The second side then printed!
The problem is solved! The printer looks a bit worse for wear, with a big hole where the button used to be, but that is of little matter to me.
Because there may be a danger of electric shock, I would advise that if you choose this repair method you use a pencil or other stylus to reach in and press the button on the switch instead of using your finger.
You may find that it will take a bit more pressure than you think it will to actually trigger the switch.
Dec 06, 2010 | Samsung ML-2510 Laser Printer
I have a broken open/close button. Can the button be replaced, or do I need to replace the whole PCB?
you need to replace a switch, which is behind the plastic button and mounted on the PCB
Nov 01, 2009 | Teac CD-P1440 CD Player
503GR Gateway
i would say try swapping your motherboard for another one to test and see if your motherboard is bad if that doesnt work take it to a computer repair store
Oct 17, 2009 | Gateway 503GR PC Desktop
I have a Gateway 503gr desktop. When I press the on button, the computer shutters but does not turn on.
I suggest the power supply is bad. Your Gateway 503GR uses an ATX style power supply. The style found in about 90 percent of desktop computers.
http://support.gateway.com/s/PC/R/3724/4172nv.shtml
(Click on Components. Then click on Power Supply in the list)
http://support.gateway.com/s/POWER/102015/102015nv.shtml
Uses a 300 watt power supply. I suggest Tigerdirect or Newegg, for a replacement. If your computer is dirty inside, I also suggest cleaning it out.
Use a can of compressed air for computers, WITH the computer unplugged from the surge protector.
Apr 22, 2009 | Gateway 503GR PC Desktop
Front Panel switch
Please contact the reseller that sold you the computer
Mar 27, 2009 | HP Pavilion a450n PC Desktop
Computers & Internet Logo
488 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
