Question about Kodak EasyShare DX7630 Digital Camera
Won't read memory card
Camera always worked fine till now. Won't read memory card, tried several, "Read only memory card, change to internal memory to capture" or Memory card requies formatting". Cards are formated, pulled card and tried using camera with just internal memory. That worked. No I don't have card locks on. Please help, use my camera a lot. Think this is my last Kodak.
  • Anonymous Dec 14, 2008
    my camera dose the same thing and i hate it. how can i fix this ? i have tired every where????????
  • Anonymous Mar 15, 2014
    32gb memory card stopped working on camera. have formatted several times
    Problem Solver:
  • 4 Answers
I hvae had this happen many times... ok this is what you will need to do. take the memory card out and look at the little brass things and clean them with something thats cotton. repeat this till it reads. i hope this will help.
Posted on Feb 03, 2009
  • 44 Answers
Sounds like the memory card socket may be damaged. It may be possible to look in the socket and see if the contacts are bent, but most likely the camera will need the socket to be replaced.
Posted on Nov 16, 2008
Nikon Coolpix L105 Camera won't read a memory card
Your camers is set that way change your settings go to menu
May 25, 2012 | Nikon Coolpix L105 12.1mp 15x Optical Zoom...
Lumix Camera won't read sd card at all.
I have the exact same problem, have not found a solution yet.
Apr 22, 2012 | Panasonic Lumix DMC-ZS6 Digital Camera
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
Camera won't register that there is a memory card, always saving pics to internal memory
Did you use a high capacity memory card with an old camera? For example, did you use a SDHC card in a somewhat old camera?
Some cameras accept only SD card. Although SDHC card has the same shape, it won't be reconized by the camera.
Sep 23, 2011 | Cameras
Hi. I have a 16GB memory card. I checked it several times with h2testw software and it's working fine. After I shoot about 4GB I start getting "unidentified image" when I try to see the...
The canon PowerShot SX210 IS only supports memory cards up to 4GB in size. Larger ones will work, but because of the format type the camera uses, it won't be able to read correctly past 4 GB.
May 05, 2011 | Canon PowerShot SX210 IS Digital Camera
Cannot get the camera to use SD card. Card inserted correctly, also it is the right size [1gig] card. Camera fails to read card, place pictures on it. Cobra DC8200 BK
It is possible that you have pictures on the camera's internal memory and as long as they're there, the camera won't use the card. You can test this by removing the card and then try to review pictures. If they show up, then the internal memory is playing. To get rid of them, with no card in the camera, go into the menu and find "format" and follow the on-screen instructions. After that, your card should work properly.
Apr 14, 2011 | Cobra Digital DC8200 Digital Camera
Camera says this card cannot be used on power up.
either the card is not supported or it needs formatting
Nov 25, 2008 | Nikon COOLPIX L5 Digital Camera
Wont read sd card..screen shows card locked..card ok
There is a little slide switch on the side of the memory card. Good luck!
Jan 02, 2008 | Aiptek IS-DV2 Camcorder
Kodak EasyShare DX7630 Digital Camera Logo
375 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
