Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Fax machine error
My fax machine gets a busy signal right before it starts dialing. I get a dial tone, then I hear the busy signal even while it is dialing out. The call doesn't get through and I have reset to defaults to try to keep it from doing this with no results.
I called Kodak support and had to upgrade firm software and reset all the settings to reflect whether I had an answering machine (yes) and call waiting (no). Also found it helpful sometimes to dial out using commas after the 1, to keep it from ringing busy.
Posted on Nov 04, 2008
I have a Brother mfc 290c. My problem is it won't send faxes, it keeps saying "no response, busy" I have a duet line. I have tried every combination in the book but still can't seem to find the solutions...
If you get the "busy/no response" message it is because the fax machine does not get a response when it tries to dial out.
Make sure you have a dial tone by pressing the "hook" button. If you do not have a dial tone, make sure the phone line is connected to LINE on the machine.
If you have a dial tone, try dialing the fax number. If you hear a recording, there is a problem with the line.
One of these two possibilities is causing the problem.
Thanks,
Pat
May 12, 2010 | Brother Office Equipment & Supplies
When I dial a fax number I get a busy signal even though I know that the number is not busy because I have dialed it on my outside line and it works. This has happened repeatedly. I have unplugged...
Since you mentioned that you have an outside line, do you have to use a code to dial out normally? Try plugging in a phone to the line for your fax machine, and attempt to dial the number for the other fax machine using the phone. You should reach the fax and hear a high pitched sequence of tones. This is the other fax machine trying to establish a connection. If you still get a busy signal, try calling the owner and letting them know that their fax machine is not accepting incoming calls.
Feb 22, 2010 | Brother IntelliFAX 770 Plain Paper Thermal...
Every time I try to fax I get a busy signal. I tried to fax several places and I get the same thing cannot be completed as dial.
dial those numbers from a regular phone and listen for fax tones. If you hear a busy signal, then they are busy.
Jan 14, 2010 | Brother FAX-575 Plain Paper Thermal
None of our faxes are going out and we receive error number 87
set the fax so you can hear dial tone... if no dial tone then check the fax line.... if fax line plugged in... plug it out of the fax and plug into a phone... if still no dial tone then change fax cable... if dial tone... then call your cell... if static... fax wont work call phone company... if you get a funny signal call phone company...
Dec 10, 2009 | Office Equipment & Supplies
Problem: Busy/No Response on all outgoing faxes
Put the document you want to send into the transmit tray, pick up the handset, listen for a dial tone, and then dial the # on the keypad..
It should ring just like any other phone. When the machine on the other end picks up and you hear the tones, press the start button.
Anything other than fax tones on the other end, it is not your faxes fault.
Nov 05, 2009 | Brother IntelliFAX 2800 Laser Fax
When trying to fax, iam getting a fast busy signal, this problem just strated
This could be related to the fax machine, but more than likely it's a phone line issue. Try sending a fax manually by using the fax machine's speaker or "on-hook", then manually dial the number. Listen carefully as the machine dials and make sure it's even dialing out. Do not hit start until you hear the other fax machine pick up. If the "fast" busy signal occurs before dialing is complete or right after, have your phone line checked.
Aug 29, 2009 | Office Equipment & Supplies
Status 50 on a fax estudio 45
the number is busy. Try pressing the monitor button and listening for a dial tone. No dial tone means your phone line is not working. If you have dial tone, dial the number you wish to fax and listen to see if it picks up. If you get a busy signal, or hear someone answer, that is why it's not working. If you hear the fax tones, press start and send your document. This is a way to fax that allows you to hear the whole process.
Aug 10, 2009 | Toshiba E-STUDIO 450 Copier
Have dial tone, but can't fax
It sounds like the modem is bad a possible electric serge
Jan 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 4100
Press speaker can you hear dial tone?
Try ringing you mobile from fax does it ring?
After dialing correct number with (outside line prefix if required) press start
Oct 18, 2007 | Brother IntelliFAX 4100 Laser Fax
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
138 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
