Question about HP Jetdirect 170x Print Server
Jetdirect 170x External Print Server Not Visible over network
I just setup a HP Jetdirect 170x external PS with a PC connected to a router where the print server is connected to another socket on the SAME router.
I used the HP Wizard to setup the printer and it works FINE! I can see the printer in a big long list of others (in my office building).
When I tried to repeat this procedure for other computers on the network but not connected to the same router I am unable to see MY printer using the wizard. However I can still see all the other printers in the big long list.
Where has my printer gone on the list and why is it not showing? Is there some sort of firewall preventing the print server information getting past the router?
Many thanks
Tim
  • togara Dec 19, 2008
    I have a jetdirect 170 x print server connected to a HP G95 printer with a parallel port. The srever is plugged into a wireless router. I got the ip address of the print server, but can't figure out how to configure DNS Servers
    Scholar:
  • 53 Answers
It is possiable that a firewall is in the way, but more likely is that you are on a different logical network or subnet.
the HP software relies upon doing a broadcast to find HP printers, broadcast traffice is not normally permitted between subnets, this is why the HP software does not find your printer.
basically you need to creat a new port on the computer in question and then associate a printer to that port.
do so by doing the following on XP pro.
get to the printers folder then click from the menu "File"
click "server properties"
click add port and then double click on the (Standard TCP/IP Port) a new wizard opens click next
in the top box enter the ip address of your printer. and click next. leave the device type as "Standard and as generic network card) click next then finish. then close.
now you have to link your printer to your new port.
install a new printer
making sure that you select local printer... but removing the tick "Automatically detect......" then click next and select LPT port 1.
click next choose HP on the left colum and HP lasterJet III from the right colum. click next give the printer a name of your choosing. and if nesseary choose if you want it to be a default printer or not.
click next and leave do not share selected.
click next
on the "do you want to print a test page " select "No"
then finish.
once done
right click you new printer select properties
then select the "Ports" tab
scroll down the list until you see new Standard TCP/IP port listed, select your port. then click apply
lastly click the advanced tab
using the driver part of this screen you are able to select the correct driver from the dropdown list if it is not avaliable click the new driver button and follow the prompts.
click OK when done.
hope this helps.
selecting the HP Laser Jet III making sure that the
Posted on Nov 08, 2008
How do I set up an HP JetDirect 170X Print Server with Windows 8.1 Operating System?
Connect the printer to the print server. Push the test button on the test button on the print server. Two pages will print. One of the pages will contain the IP address for the print server. Connect the print server to the router. Now you need to go to the Control Panel and select "Devices and Printers". Select "Add a Printer". When it searches for a printer, select "The printer I want isn't listed". Next, select "Add a printer using TCP/IP address or hostname" and click "Next". Now, enter the IP address from the test print and click next. That will do it.
May 28, 2014 | HP Jetdirect 170x Print Server
Why is my jetdirect en3700 not picking up laserjet 1020?
Laserjet 1020 is a Host-based (WIN) printer. It must be connected to a Windows PC directly.
Apr 25, 2014 | HP JetDirect en3700 External Print Server...
How to specify a host name for jetdirect 170x
Connect the print server to the router with an ethernet cable and connect the server to the printer. Find the IP address for the printer/server by pushing the "test" button on the print server. The IP address will be listed on the paper printed during the test.
Nov 12, 2013 | HP Jetdirect 170x Print Server
How to change the ip address of a hp jetdirect 170X
The manual is located here, and it recommends the following procedure, which starts on page 18.
Connect the Jetdirect box to the printer and the network and power on.
Press the Test button on the back of the Jetdirect box to print a configuration page.
The configuration page should show the IP address of the Jetdirect box.
If this is an IP address in the normal range of your network, ie the first three numbers of the Jetdirect box's IP address and your computer's IP address is the same (such as 192.168.0.) then simply type the IP address into your computers internet browser and you can reach the configuration page. The steps on page 58 detail the user interface for the web login.
If the Jetdirect box does not get an IP address withing 2 minutes of it booting up, it assigns itself an IP address of 192.0.0.192, and you can connect to it over the network if you change your own network settings to 192.0.0. and a number from 1-254 (but not 192).
May 04, 2011 | HP Jetdirect 170x Print Server
I'm pretty good at most computer stuff, but I'm stumped. I'm trying to connect an HPlaserjet5/5m to an HP 170X Print Server on a 16 port dlink switch. I cannot get the hp setup.exe to work off the...
I am not sure if you need the setup.exe file to configure the JetDirect 170x.If you take a look the manual for the JetDirect 170x (http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00758101/c00758101.pdf) it mentions that this is a "Test" button on the back of the print server. If you press that button when the printer is connect, then it should print out a configuration page. The configuration page will have an IP address that you can browse to with Internet Explorer to configure the JetDirect.
Jun 05, 2009 | HP Jetdirect 170x Print Server
HP DesignJet 450c printer issues.
You can purchase a External JetDirect card from any reputable HP (or computer) agent. This will allow you to plug the 450 directly into the network. The problem with the large format printers not being supported is strange to me. I have never had a problem, simply load the drivers and away you go. If the 450 drivers dont work for you, you can select any of the older drivers (750c recomended) and they will work on the 450c
Feb 26, 2009 | HP DesignJet 450c InkJet Printer
I can not print when I connect to my jetdirect print server.
Hi, sorry for late answer, I have been offline for a while.
Connect RJ45 to router and parallel to computer
You need to download Software here first selecting 300x and windows version.
Then you can use the HP JetDirect Wireless Setup Wizard
to setup your printer on network.
You may also be required to install printer drivers, to do this use printer CD or download them from the Internet.
Regards
May 01, 2008 | HP JetDirect Print Server
Laserjet 2300d hasstopped printing to a HP Jetdirect 170x suddenly
parallel cable connected?
omg this? "old centronix")
IEEE 1284 standard
parallel-zw1hxsxncju1x1hxxv3nm1gz-1-0.jpg RTM yet? check the manual carefully
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=27317&docLocale=en_US&docId=emr_na-bpj06151
The HP JetDirect 300X provides connectivity to 10Base-T and
100Base-TX networks. The HP JetDirect 170X provides
connectivity to 10Base-T ne
tworks. The HP JetDirect EX Plus
provides connectivity to 10Base-T and 10Base2 networks.
HP JetDirect 170X (J3258B):
Bidirectional parallel port (IEEE 1284).
Network port (Ethernet): RJ-45 (10Base-T).
Test button (sends print server configuration page).??????????
2 LEDs on front indicate LAN activity/status
Mar 06, 2017 | HP Jetdirect 170x Print Server
HP Jetdirect 170x Print Server Logo
1,532 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
