Question about Microwave Ovens
Wolf - microwave oven not turnin ON
Supposely Wolf microwave ovens are like the Mercedes of microwaves but after 3 years of service it is not working.
Lights works, panel works but when I push the Start button - it only makes a clicking nose and nothing starts...any help is much appreciated.
wOO
Wof - MW24
  • byagiz Dec 13, 2008
    Lights works, panel works but when I push any button - it only
    makes a ping noise, reads panel locked and nothing starts... How can I unlock the panel? thanks
  • Microwave Ovens Master
  • 9,086 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Nov 09, 2008
  • Jack Irby
    Jack Irby Sep 26, 2014
    How do I access the door switch for replacement?
Wolf MWC24 turns on and spins. Does not heat on microwave or convection. Any ideas?
The Wolf DCM24 is a rebranded Sharp, similar to the Sharp model R-930AK, etc.
The Sharp version service manual is here, and while cosmetic parts won't interchange, internal ones will.
The problem you have is usually caused by a bad bottom door switch, or that switch's mount may be loose, misaligned, or broken.
See my help info on door switches here and here.
Once you look all this over, if you have other questions, please feel free to contact me by e-mail here.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 15, 2017 | Microwave Ovens
Sparks inside a wolf mw24 inside in right wall cover plate
The right side wall cover plate is the "waveguide cover."
It protects the waveguide and the magnetron at the other end from moisture, grease, and food particles.
If these remain stuck to the waveguide cover, arcing can occur, which will damage and / or destroy the cover, the waveguide or even the magnetron or the oven chassis.
As with most problems, this should be addressed sooner rather than later or it will only get worse, and may become unrepairable.
The similar Sharp model R-530E-series service manuals are here and here. They will help with disassembly, but the external / cosmetic parts will not interchange.
The Wolf waveguide number is 801798 and Wolf part ordering information is here.
The oven cavity and waveguide must be clean and if any spot is scorched or chipped, it must be sanded smooth, cleaned and dried, then touched up with appliance paint, available from local big box stores, home centers, appliance parts stores, and hardware stores.
Leave the door open overnight to dry the paint. Then install the new waveguide cover.
If the chassis or waveguide have holes in them, the oven must be scrapped and replaced.
For more free DIY and other help & advice, feel free to contact me via my site.
Dec 05, 2016 | In Microwave Ovens
How do i take out my Electrolux EI24MO45IBA Microwave?
Thank you for your post, Jared Wolf!
Based off the information you have provided you need help removing your Electrolux microwave. I have included a link that will provide you installation instructions and you should be able to follow those directions in reverse to take down your microwave. Good luck. -Matt
Frigidaire Manual Search Results
Nov 18, 2014 | Electrolux Microwave Ovens
Wolf microwave timer counts down, lights on but not cooking or making noise when started
You need a magnetron. While the cabinet is open look for melted wires, check the circuit board for burned components. Check thermal cutoffs for continuity etc
Nov 26, 2013 | Microwave Ovens
I would like to fix a door switch on wolf MW24
The adjustment does not last, the technician should have replaced the door switch from the beginning to avoid a callback and leaving a bad impression. To trouble shoot you will need a digital meter, if you have one one post back.
Jun 28, 2012 | Sub-Zero MW24 Microwave Oven
The microwave will run for a minute and then shut off
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp (and Sharp-made Dacor and Wolf) models stop after 59 seconds.
See: http://www.fixya.com/uploads/Howto/B27054B.jpg
Nov 29, 2010 | Dacor DMT2420SS Microwave Oven
Wolf Microwave -- Loud Pop and Sparks
Is it safe to use your microwave if it pops like this all the time randomly... And sometimes lights up in the back like a spark or something???
Nov 19, 2008 | Microwave Ovens
Microwave Ovens Logo
900 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
