Question about Yamaha GO46 Sound Card
Yamaha GO46 becomes a static brick!
I have had plenty of problems with audible static dealing with this yamaha go46 metalic brick - though through persistance I found the majority of my problems were coming from having an amd dual core processor - don't know how to explain how to fix the problem just yet but I'm looking towards setting the "goserver" (whatever the name of the program that lauches when you plug that bull*ish in) processor affinity to use only one processor. But for those of you who suffer this same prob dealing with amd try uninstalling the amd optimization (if you installed it) and compare your quality with what you heard before you uninstalled it. or just check your cpu load - I used FL Studio cpu load which is what helped me figure out what was causing my probs.
5 Suggested Answers
faheemsafdar
  • 68 Answers
SOURCE: Yamaha GO46 is not recognized as an audio device - wdm driver not instaled properly
  1. It may be hardware problem (IRQ sharing problem). First go to PC's bios setting and disable "Audio Device" by searching options. Try to change sound card with other Pci slot (white slot).
  2. To get it's latest driver, get free register on www.driverguide.com and after signing in type "yamaha GO46" in search bar on this site. Don't forget to vote me. Thanks
Posted on Mar 28, 2008
SOURCE: yamaha GO46 firewire audio interface
Hi. It might be a bit late, but the solution to your problem is the fact that the phones level is dependent on output 3-4. If you turn 3-4 all the way up you should be able to hear something. You might want to route all the outputs to the digital mixer.
Posted on Dec 13, 2008
SOURCE: Powerbook doesn't recognize Yamaha GO46 FW interface
Hello. I had the same problem and solved by mere casuality. If you disconnect the AC power adaptor and let the Firewire connection to be the only power supplier, then the GO46 will be inmediately recognised by the "Preferences -> Sound" panel of the G4.
Hope I've been helpful. Bye.
Posted on Sep 04, 2009
SOURCE: yamaha GO46 stop sounding without reason!!??
can be overheating. I had the same problem and opened it. It is really hot! Put a fan just above it and it works better!
Posted on Jul 31, 2010
Yamaha V star Final Drive shaft
The drives for a 650 and an 1100 are different part numbers, so it probably wouldn't fit.
However, you can buy what parts you need to replace here:
http://www.bikebandit.com/houseofmotorcycles/2004-yamaha-v-star-classic-650-xvs65as-drive-shaft/o/m145479sch295406
Feb 16, 2014 | 2004 Yamaha V Star Classic
Yamaha xmax 125 - only done 1000 miles. Doesen't feel smooth at very low rpm i.e launching from lights etc. It has become a bit noiser and Feels rougher, sometimes feels as though transmission is...
You can fix this by grinding your clutch shues (3x) and follow the round shape when grinding (more contact surface) However it will come back and you have to do it again (I hate Yamaha for this)
anny more dureable sugestions?
Jun 13, 2011 | 2011 Yamaha XMax 125
Want to download driver for go 46 vista don´t know wher to find it
Here is the website which you can download the needed driver
Thanks for the 4 thumbs up in advance as well
http://emusician.com/software/yamaha_driver_updates/
Aug 08, 2010 | Yamaha GO46 Sound Card
Yamaha GO46 stop sounding without reason!!??
Jul 14, 2010 | Yamaha GO46 Sound Card
Laptop into my YAMAHA HTR-6130 Receiver has Static
One possible reason would be a damaged ground in the cable (check with a DVD/CD player or any other device if possible to see if static persists.) if it is not the cable, then try plugging the laptop into the same power outlet as the Yamaha receiver and see if static persists. if static no longer persists, the problem is a discrepancy in the grounding on either end causing static in the signal and you can either buy a filter at most electronic stores. or you can just continue to use that power outlet if it is not an inconvenience. if it IS the cable, well, replacing it should be fine.
Jan 18, 2009 | Onkyo TX-SV444 Receiver
Yamaha GO46 firewire audio interface
Aug 23, 2008 | Yamaha GO46 Sound Card
Audio from go46
sounds you have 2 channels set on stereo maybe not mono ?
Aug 07, 2008 | Yamaha GO46 Sound Card
get a new soundcard GO46 is a bag of trouble. I had to get a special Firewire Card with a Texas Instrument chip, since the cheap internal firewire interfaces don't work with this card. Also make sure you are not running XP64, since it is not supported. good luck
Mar 27, 2008 | Yamaha GO46 Sound Card
Can't record in stereo
I have a tascam 144 that came with cubase. I am not able to figure out Cubase either. I am a beginner and am trying to record my yamaha electric drum set with it. so far no luck at all.
Feb 25, 2008 | Tascam US-122 USB Audio/MIDI Interface...
Oct 27, 2007 | Yamaha GO46 Sound Card
Yamaha GO46 Sound Card Logo
103 people viewed this question
Top Yamaha Computers & Internet Experts
Tony
Carlos L. Burgos
Carlos L. Burgos
Are you a Yamaha Computer and Internet Expert? Answer questions, earn points and help others
