I would first check to see if there is a flame present. If there is, and there is no cooling at all, make sure you are perfectly level. If you are level, check for yellow powder or residue back around the cooling unit or any smell of ammonia. Norcold Guy has an article on this that says it's probably a cooling unit that needs replacement: Bad Norcold Cooling Unit cooling unit replacement
-or- What Causes Norcold Cooling Unit Failures
Does the rear of the cooling system get warm? If it is level and the cooling unit is getting warm while the refrigerator is still not cooling then you could possibly require a replacement cooling unit. Give Arcticold a call 1-888-782-6665, we can help diagnose the problem free of charge.
Sir,
To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant.
I suggest you to contact the service authority.
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Go to www.bryantrv.com and go to "service documents" and download the manual for your model "Norcold N Series". It says that 5 blinks then a pause means "no cooling detected by controls" see page 21 & 37.
