Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Your model Samsung falls under a class actions settlement. These units have defective power supply boards and Samsung has agreed to pay for the repair / replacement of the boards at no cost to the user even if the unit is out of standard warranty. This sounds like the issue with your TV. Here is a link with additional information about the settlement and how to get the warranty work completed.
the problem is in the power supply or in the horizontal output section HV.it can be the tv has a blown fuse a regulator damage.or the horizontal transistor is damage if you have no knowledge of electronics.take your tv to a repair tech.good luck.
I had the same problem with my Samsung LN26A450 LCD TV. I found the following YouTube video http://www.youtube.com/watch?v=Mm51C_RDIZE titled "Samsung TV Repair - Part 1 of 2) (also watch Part 2 of 2) which shows how to easily fix the problem. The problem is bad capacitors on the power supply board. My TV had seven (7) bad capacitors - all 7 had dark stains on the ends from leaking electrolytic fluid and one (10V 2200MFD) was blown with bulging ends. I ordered 7 new high-temp (105 degrees C) aluminum radial capacitors from DigiKey.com matching the Temperature, Capacitances and Voltage Ratings for each damaged capacitor that I removed. I followed the instructions in the video except I used desoldering braid ($3.99 at RadioShack) to remove the solder attaching the bad capacitor leads to the power supply board. Once you wick up the old solder from all sides of each lead wire using the desoldering braid, the bad capacitors are easily removed. Total cost of repair including soldering equipment was less than $50. Thanks to “The Professor” for posting the video and saving me $400.
Greetings. I have a Samsung LN26A450, turn on and normal listening but no video, the screen is black. I opened it and found the F4 in the inverter card open, stamped value says "15" on the board says "0.75A/76V", I put that value and reopen, maybe the value is 1.5 A or 15A ?. I measured most components in the board and are ok.
