Question about Canon PIXMA iP4200 InkJet Photo Printer
Canon ip4300 ink absorber is full
I have cleaned the absorbing pads, but the printer is still showing me that the
absorber is full, how do i get to make it sense that i have replace the pads?
  • 421 Answers
You need to reset the waste ink counter. The printer doesn't know that you have replaced or cleaned the pads you need to tell it.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Hope that helps, if it does please rate my solution.
Thanks
Posted on Nov 14, 2008
Canon Pixma MX300 ink absorber cleaning video ; how can I clean the ink absorber?
When the ink absorber pads are full, you can easily remove and clean them on most Canon printers. Fill a large bowl with warm, soapy water and set it aside. Put on the rubber gloves. Open the ink cartridge compartment.
How to Clean a Canon Ink Absorber ' Chron.com
smallbusiness.chron.com/clean-canon-ink-absorber-57609.html https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Canon+Pixma+MX300+ink+absorber+clean
Nov 26, 2016 | Canon Office Equipment & Supplies
Tip
Ink Absorber Full on Canon Printers
When you see the error "Ink absorber nearly full" or "ink absorber full" you
really need a shop to replace the ink absorber. The error is generated by firmware in the printer or multi-function that counts the number of prints, power cycles, and cleaning operations. It is not a sensor or gauge inside to be reset. The absorbers are thick pads covering the bottom of the print engine and all waste ink from the purge assembly is directed through channels and tubes to these absorbers. You should never reset the error code without fresh absorbers installed as the ink can fill inside and ruin the printer or damage the furniture the printer sits on. The absorbers are fairly cheap, from $10.00 to about $20.00 and after changing the pads the Canon repair person will enter the service mode and reset the counter. This operation is well worth the expense as a good technician will clean and lubricate the printer at the same time ensuring you of longer trouble-free printing.
on Dec 31, 2009 | Office Equipment & Supplies
Canon IP90 ink pad is full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Feb 11, 2013 | Canon PIXMA iP90 Mobile Printer
Ink absorber is full
Canon printers have an ink absorber that soaks up any excess ink. When this is full it can cause problems with your printer. You can send it in to be serviced but a much cheaper option is to replace the pads yourself or to try cleaning them.
See this link for detailed instructions how to change the pads:
http://www.ehow.com/how_6154288_replace-ink-absorber-canon-printer.html
Jul 15, 2012 | Canon Office Equipment & Supplies
In printer canon ip 1800 is showing ink absorber is full cant use the printer
Hope you find this information helpful.
The printer has a built-in ink absorber to hold the ink used during Print Head Cleaning, for example. Eight flashes indicates that the ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer. Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced
Mar 31, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Waste ink absorber full
Open your printer.
To protect hands from Ink wear thin latex (or similar) gloves
Locate the Waste Ink Pads on the inside of your printer
. They are on the right hand side and are quite small.
You can remove the pads and the holder with a gentle pull
Using a tissue, soak up as much ink as possible and clean the area around the waste ink area
There is one more waste holder in the right back bottom of the printer. A kind of sponge. There are few screws and plastic parts to be removed and this sponge needs to be washed, dried and placed again. Be careful and patient. This is no understatement. Take a photograph (even with your cell phone) so you can trace back your steps. You also need to take care as you lift the slide/carriage. Below this you find 5 little springs.
Carefully replace the holder and the pads
. Close printer.
Whilst printer is disconnected from the mains power, press and hold the power button and reconnect to ac power
Release the power button
Press the power button again
Mar 03, 2011 | Canon PIXMA iP1800 Printer
The ink absorber is full What can I do?
if the printer shows ink absorber full on display you have to firsst physically acess the ink absorber pad then clean it up by removing the excesses ink from the pad ,follow the step below to do this
STEP 1:
- Disconnect printer from AC power supply
STEP 2:
- Press and HOLD the POWER button, and connect printer to AC power
Power up with the cover open until the head moves to the left side then disconnect the power cord so that the head is positioned away from the pads. raise The two pads easily with a pair of sharp tweezers and the rinse in running water. it will become white again and can be blotted with paper napkins then air dried in a warm location(may be in an oven) . cleaned the wells in the rubber holdet with cotton swabs before returning the two pads
Dec 19, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
If ink absorber is already full what should i do next?
it is not possible for you it is the problem mantainence wast tank full it mean when we print then chack cartridge is automacily clean then some ink fall under pad this pad is full ink then machine say ink absorber tank is full
you go to aservice centre only support printer canon. Thy clean wast tank and reset your printer
Jul 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps ... Cheers :)
Aug 13, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
1,236 people viewed this question
old marine
old marine
