Question about MSI Microstar KT6 Delta (MS-6590) Motherboard
Sata hard instalation
Hi
I have a msi kt6 delta main board but it not detect my sata hard.
my raid controler chip is VT8237 and I test all bios version (5.0~5.7) for detection of my hard. my hard work with other intel support motherboard by sata cable. please hint me
very thanks
  • mehrdad856 Nov 04, 2008
    hi
    dear colliewob
    yes,first I had an IDE hard drive with my sata hard, then I removed it and cheked but it not detect too!
    thank u
    I am waiting for solution!
  • 781 Answers
Do you have an IDE hard drive fitted as well.
If so remove it as I have found out that unless setup properly IDE and SATA do not mix
Posted on Nov 04, 2008
How to boot from dvd using MS6590 ver 2.0 with VT8237 controller
Turn the computer off.
Turn the computer on, and look for the message:
Press <BLAH> to enter BIOS SETUP.
Press the <BLAH> key.
Change the "boot-order" to make the CD/DVD the "first" boot-device.
Save/Exit from BIOS SETUP.
Insert the media into the CD/DVD device.
Boot from the media.
Aug 02, 2011 | MSI Microstar KT6 Delta (MS-6590)...
Mother board masi km4am-l H.D.D. 1 TRA WES 64MB when installing win xp hard not detected by win setup. I updated bios but not worked. advance thanks
you should not update the bios...the issue is the hard disk is on sata ...and you need a raid driver installed to detect the hdd...so ...either get into BIOS and under advanced features..look the place where the drives are detected..and select the hdd and look for a feature called AHCI ..and disable it ..and leave sata like ide..and save with f10 and restart ...after that the hdd will be seen ..
another way is to make a floppy disk with the raid driver on it (the one from the mothermoard drivers disk ) ..and when it ask you to press f6 for 3rd party software ...press it ..and insert the floppy ...it will pick up the raid driver and will go like a charm ..
if you do not have a floppy ..install a second cd drive ..and use a cd ..and after pressing f6 for 3rd party ..browse and point to the raid driver on the mobo driver cd ..
Jul 15, 2011 | MSI KM4AM-L VIA KM400A CHIPSET ULTRA...
I am not able to detect sata hard disk in msi mother board
Your model K8MM-V motherboard does not have a SATA controller only IDE disk controllers and therefore it cannot detect a SATA hard drive.
To install a SATA hard drive on this motherboard you need to purchase a PCI SATA disk controller and install it on the PCI expansion slot and then attach the SATA hard disk to this SATA controller.
Aug 21, 2010 | MSI K8MM-V Motherboard
BIOS update on MSI KT6 Delta (MS-6590 v2 5.0)
You should be able to get it from here.
http://www.motherboard.cz/driver/msi.htm
Apr 26, 2010 | MSI Microstar KT6 Delta (MS-6590)...
Can't connect SATA Hard Drive to MSI PT8 Neo-V Mother Board
You tell where in the System or in the BIOS. In BIOS on the SATA Mode or RAID Mode while in the System you install RAID Software to recognize and detect any SATA or RAID Hardware.
Sep 29, 2009 | MSI PT8 Neo-V Motherboard
New SATA Hdd detection problem
Have you checked in the bios setup of the motherboard if your SATA ports are enabled?
Let me know if you need further assistance.
Regards,
Graemevm
Apr 19, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
Need to add SATA controller driver
Hi voyager99,
You can download the driver, (VIA 8237 SATA/RAID driver) from PC Chips but I doupt it will help.
If your bios did no see the 250GB drive than the onboard SATA controller is defective. This can not be fixed.
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=305&DetailName=Driver&MenuID=1&LanID=0
Running the SATA/RAID driver will most likely not help the bios see your drive.
Buying a PCI serial SATA controller card may allow your SATA drive run but it will run at the PCI bus speed. A decent controll card may cost as much as a new board that will run your current devices.
Mike
Oct 16, 2008 | Pc Ware PC CHIPS: PC-Chip M957G...
Disco duro serial ata
Hola VooDooNOFX
Gracias por la ayuda
No estoy configurando los dos discos duros apartes ni haciendo raid a los dos juntos.
El D.D. de 80 gb IDE ya esta parcicionado y formateado (40 c/u, FAT32), tiene windows xp sp3. Uso teclado PS2.
En el D.D. 250 gb serial ata quiero particionarlo en cuatro partes e instalar windows vista, las otras tres particiones para datos.
Voy a hacer esto: Desconecto el D.D. 80 gb IDE y dejo solo instalado el D.D. serial ata de 250 gb para partionarlo y formatearlo con windows vista; primero sin desactivar la función de raid en la bios y luego desactivandola; que opina.
Sep 16, 2008 | MSI Microstar KT6 Delta (MS-6590)...
Sata raid config
first check your bios & see what raid chips are enabled,usually there's 2. Your main raid is on the first 4 sata connectors, the other chipset probably controlls the remaining sata ports. So if there's an option to disable one raid chip,disable one,just not the one that you're using. I don't know what your bios screen looks like,so this is just a general view based on my experences with various boards,mainly asus.
Jul 13, 2008 | Abit AW9D-MAX Motherboard
MSI Microstar KT6 Delta (MS-6590) Motherboard Logo
386 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
