Question about Whirlpool Duet GHW9150P Front Load Washer
Washing machine stops working
I have a whirpool ultimate care II and it was working perfectly till last week. The washer fills up with water and then the spinning cycle does not start. I have tried changing the load size, taking off clothing, unpluging the maching, restarting, everything, but nothing happens.
I search in the internet on regards to the problems with the Whirpool Ultimate Care II and found out that many others had the same problem as I did. Some solved this issue replacing the switch, so i decided to do the same.
I opened the machine and saw that the switch was not working properly, it was not doing any contact, so whenever I open or closed the lid, nothing was happening. I did a house fixing, with some duck tape i was able to make the system work, and now the machine is washing everything again.
Posted on Nov 04, 2008
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    My Whirlpool Ultimate Care II Washer doesn't stop filling with water
    If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
    Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirpool Ultimate Care II washer - drips
    Your water inlet valve is leaking through. Turn off the water. Remove the hoses from the washer. Clean the sediment screens in the water valve and replace the hose.
    If that does not solve the leak through problem,the water inlet valve will have to be replaced.
    Use the attached video to show how to access the inside of the washer in the event the water valve needs replacing.
    http://appliancejunk.com/forums/index.php?topic=5191.0
    Nov 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool ultimate care II stops after filling
    Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
    Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
    Whirlpool Ultimate Care II keeps taking water.
    ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
    Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    The load won't start.
    It sounds like you have a bad lid switch.It's an easy fix.You can get the part at your local appliance supply.
    Dec 09, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Remove top of machine, you will find lid switch or 'sensor' there. I would say its faulty ,and needs to be replaced.g,luck.rate me
    Dec 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Duet GHW9150P Front Load Washer Logo
    141 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
