I keep losing my interent, i disconted it cant get it back on line for a couple of days
  • 68 Answers
Double check the settings of your firewall, or try to scan your system to check if there is a malware, and also double check what program did you add before this problem started to happened.
Posted on Nov 03, 2008
Works interment. seems to not be getting enough power
you are correct not enough power if worked before possible motor drawing too much power
Oct 12, 2015 | Dometic Heating & Cooling
I have a 1997 SAAB 2.0 Turbo and it has started to run rough after it warms up and when driving it loses power and runs very rough until power taken off. Any ideas?
suspect low fuel pressure to the injectors
run the fault codes to determine where the fault may be before you spend money
Oct 09, 2015 | 1997 Saab 900
My printers keeps losing its connection to my laptop and Ipad and I have to keep reinstalling every time I want to use them together.
It may be losing its IP address. Check the DHCP address affectation of your router. And leave your printer constantly connected to the router. You should also let your printer get the IP address automatically upon booting.
Nov 07, 2013 | Canon PIXMA MX712 Wireless Inkjet Office...
1997 Grand Am overheated. Fan, temperature gauge changed. Head gasket replaced. Car was running fine, couple days later, acted like it wanted to overheat, why does it keep doing this?
I think you need to clean your radiator(open water tank and remove all dirt inside it and inter in water hols and pipe thin stick), change thermostat to lower degree heat, if the problem continue try to remove thermostat.
Mar 20, 2013 | Cars & Trucks
I have a Frigidaire side by side frig, model FRS20ZKG. My supply inlet to the ice maker keeps freezing which after 2-3 cycles will not make any more ice because no water can make it to the tray. This...
The supply inlet to the ice maker is connected (via metal coupling) to the radiator-like-coils in the freezer which are actually hot and they keep the line from freezing. If this coupling is not connected close to a heat source, then the supply line can freeze as you are experiencing.
If possible reroute the supply line out of the freezer area
Sep 23, 2010 | Frigidaire Refrigerators
Laptop keeps losing wireless connection
make sure the wep key you apply it is correct.just reconfgure the wireless connection.
Dec 31, 2009 | Dell Inspiron 6000 Notebook
My acer laptop is about 6 months old and was working great till few weeks ago , i had to format few days ago because it was lagging overheating missing files discont me on line every 2 mintues , wouldnt...
If your internet is not working properly then reset your router and configure again.
Scan your computer with updated antivirus.
Also check RAM memory is works fine.
If it over heat then put extran fan so it control heat.
let me know if you need further assistance.
Thanks.
Oct 30, 2009 | Toshiba Portege 7100 Notebook
Cant connect to the interent
Hi
Actually you lose your net setting in phone just call to customer care they ll give you setting just type & enjoy
Harry
Jun 02, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
My 2wire modem keeps diconnecting
hello,
this can be a couple of things one that you keep losing signal from your ISP keep an eye on your DSL nad ETHERNET light
if at any point they turn red call your ISP try not to set that modem to close to the monitor on the ground basicly any whenr where their could be static next to the refidurator or a TV
static make modem restart
another thing is that this might be early signs of your modem going to brake
, JULY
rate my service please
Apr 11, 2009 | 2wire (1000-000057-000) Modem
Inter-Tel Axxess holding.
In System Timers there is a Hold timer and an Alternate Hold timer. The max that you can extend it to is 255 seconds. Please be advised that this is a system wide timer. If you are the only one that wants this then you should change your keyset to have the alternate hold timer and then extend it to 255. If you want this system wide then you should change the Hold timer and you should be good to go.
Jan 04, 2007 | Inter-Tel Axxess Corded Phone
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
