Question about Broksonic CTSGT8118T 13 in. TV/VCR Combo
Doesn't record when timer is set.
Unit will record manually, will not record when timer is set?
I found the manual and helped me get familiar with the remote etc. Tech. support solved my problem i was pressing the otr rec button instead of the timer rec button. Ken.
Posted on Nov 27, 2008
Set vcr to record after timer is set
You need to turn off the Timer and then add your new program to the schedule. Then turn the Timer back on (power off).
On most VCRs, the Timer is enabled by turning off the unit. Thus turning it on will work (as long as a program isn't currently being recorded). If a program is currently being recorded, press Stop to interrupt the programmed recording. Then add your new program - that doesn't conflict with other programmed recording or exceed the number of available timed recordings for the unit. Then turn off the unit.
At least one VCR I owned was a bit trickier. You had to press the Timer button on the remote instead of the power button.
I hope this helps.
May 16, 2013 | Emerson New Original VCR4010A Remote...
Magnavox MDR515H will not finalize
clean the OPU unit ( objetive LENS ) WITH disk cleaner. and fix it.
otherwise read your instr. manual go to the section troubleshooting
or download your instr. manual www. retrevo.com
If the problem persist you must go to the repair shop TV for fix it.
God bless you
Sep 30, 2012 | Magnavox MDR515H HDDVD Recorder
VCR Recorder VC-H982 Can't time record. can't select a channel other then 3, 40 av under timer. What is pdc?. where dose it appear. what is sap in set up window? what is air in the channel...
You will probably find a free manual at the Sharp website. That should answer most of your problems. However can tell you that PDC stands for Programme Delivery Control. With it on, say you want to record a program that starts at 9pm and finishes at 10pm. Then all you need is set the control to on, when you set the timer recording, and the video will record your show, even if it starts at say 9.10 and runs while 10.10. The VCR will wait till 9.10 to start and stop at 10.10. Good if a sporting event or live event overruns!
However PDC doesn't work on digital and will not work sometimes at all or if you set the timer wrong. It uses the old teletext signal, which is why if you are in an area that has gone over to digital it should be set to off! As it will never get a PDC signal!!!!
Jun 04, 2011 | Sharp VC-H982U VHS VCR
Teac hdr2500t Go to stand by after recording
Don't know for sure, only bought the unit yesterday, but apparently if you set a recording time past the timer recording completion it does switch off. Have to try it first. As I said I am not sure. Very impressed so far. Works a treat and no major problems
Oct 29, 2009 | Televison & Video
Samsung DVD-4600 won't record with VCR timer set
Press fast forward and rewind button on the unit simultaneously for 10 seconds with no disc inside the player to reset it to factory setting.
Aug 19, 2009 | Samsung Televison & Video
Timer VCR Recording for a Toshiba MV13M2 13 in. TV/VCR Combo
Hello, you can go to the toshiba web site and download the manual from there.
The other option is to go into the TV menu, and select the timer rec set selection and access it there and fill in the times for the program you want to recording and that should do it.
I hope tihs helps.
BWLY
Jan 23, 2009 | Toshiba MV13M2 13 in. TV/VCR Combo
Magnovox MWR20V6 will not begin recording when it should.
This is more a work-around than a solution, as the unit is failing to function normally; however, having the identical problem I observed that the unit is failing to power on at 2:00 minutes before beginning recording, a necessary step to record to DVD.
My work-around is the following:
1) Set up the timer, inputting necessary date, time, etc. as normal. With the unit still powered on, start the timed recording mode by pressing timer set, as normal. You will see the red clock icon and the DVD logo iluminate on the VFD.
2) Press the Standby-On power button. This will power the unit on in VCR mode. You should at this time be unable to switch from VCR to DVD mode since the DVD is still in timer mode. LEAVE THE UNIT POWERED ON in this manner. The timer will function and the DVD will record normally.
I have no clue why my unit suddenly forgot how to power up on its own in order to record to DVD. If anyone has an answer for that one please post!
Tom Gee
May 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Samsung DVD-SH855
Hi Thanks to all. Problem was solved by my son who suggested that I turn the unit off in standby mode. Samsung DVD-SH855 will not record via timer settings when the unit is left with pwr on. Only works if pwr switched off.
Had I known this prior to purchasing I would have purchased a brand that worked with pwr on.
See:
http://www.avforums.com/forums/archive/index.php/t-617483.html
Apr 30, 2008 | Televison & Video
LG DBRH197
Read the timer record troubleshooting suggestions - timer record will only start is the unit is turned off!
Jul 03, 2007 | LG DBRH197H DVD Player/HDD Recorder
Weekly timer recording not working
Have you tried setting the clock to manual mode: Page 18 in the manual I think.
Jun 30, 2007 | LG DBRH197H DVD Player/HDD Recorder
Broksonic CTSGT8118T 13 in. TV/VCR Combo Logo
89 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
