Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
No picture do have sound
While watching the TV, it was as though the focus was out of whack then all of a sudden the picture disappeared and a blip noise was heard as the picture went out.
  • rjayones Dec 06, 2008
    Lost the picture. When I hold the power button on the remote for 2 seconds, the red light comes on on front of TV, then blinks 9 times, then nothing. I never get a picture on screen.
  • 2,920 Answers
I think you have a blown tube.if theres no pic but sound youve got a blown tube
Posted on Nov 17, 2008
How to change a bulb in a apex pf2720 tv
I'd guess it is not a bulb issue if the audio also stopped working. Check your input source, connections and the like. Try using a different input (ie input 4 or the front AV connectors) and a different source (ie your old Nintendo instead of your DVD player).
Nov 17, 2011 | Apex Digital PF2720 27" TV
Picture went off on rca flat screen while watching still have sou
That probably happened because something hit the TV and broke the line for pictures to get through, or because a wire in you TV is bad and doesn't wanna work. This happened to my TV every few days. What I did is give it a few whacks every now and then on top of it and the vision came back, but don't try that if you think your TV is fragile. Yes I know its sounds stereotypical but it actually sometimes works.
Well, good luck!
Jun 04, 2009 | RCA TruFlat 27F520T 27" TV
Lcd tv pictures flickers on/off but power light stays on
you'll probably find the power supply of the lcd is broken. try getting a new powersupply and try to work it then
May 09, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Trinitron - Picture Disappears
Hi, IK circuit is engaging which basically means the picture tube is getting tired, the only "fix" is temporary (may get another year out of it). You have to increase the "screen control clockwise".
Remove back of set, follow large black or red wire attatched to picture tube down to the flyback transformer, mounted on flyback are two black controls, one is focus (leave it alone) the other is "screen", adjust it clockwise approx. 1/4 inch, remember that this is a high voltage circuit so use one hand in the set the other hand out of the set at all times,any questions ? e-mail me back, good luck, BMW Rider
Feb 27, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Phillips 29" TV
Sounds like it has an intermittant connection somewhere which is very common now a days due to the lead-free solder all the makers went to. Resolder everything that looks suspicious, especially the bigger components. It could also be a failure of the flyback transformer though which often times fail like this.
Hope Ya Fix It.
Feb 13, 2008 | Philips 27PT6441 27" TV
Pic problem
Quasar TV SP3232. Picture disappears but comes back by striking the TV . The sound keeps coming. Perhaps something is loose
Dec 23, 2007 | Quasar SP-3235 32" TV
No sound
Hi, Probably you first have to determine if the "no sound" is the TV or your source (cable box). Try another source such as a DVD player hooked to the audio/video inputs of the TV, if still no sound then you have confirmed that it is the TV, if there is sound, then it is the cable box (in some cases it may be just the cables connecting the cable box and the TV; try wiggling it a bit, might just be loose). If it is the TV, go through the routine of the setup/menu; look for audio, stereo, SAP, etc, try different settings (pls log down original setting in case no change and you have to revert back). If all else fails, try the "thump test" this will help you determine if its a loose/cold solder problem inside the TV. Give your TV a good whack at the side, top or back, if sounds comes on even briefly, it's a loose/cold solder problem, if not then you probably have to have the unit serviced by a qualified professional. Good luck and kind regards.
Aug 26, 2007 | TruTech PLV16320 Television
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
108 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
