Question about GE JGBP28 Gas Kitchen Range
GE Gas Range
What does it mean if my gas range shut off and flashed F2 in the middle of baking??
sanderson@fwmoh.com
    Scholar:
  • 62 Answers
Do you have the manual? Normally , if I remember right it is either a sensor or control board. If it is a problem that can be solved w/o a tech the manual will give you sugesstions. I could be wrong on the code but you could try unplugging it for15-30 min then plugging it back in and try again. Don't have the manual? I'll try to find the code reference if I can.
Posted on Nov 05, 2008
My ge xl44 gas range, installed in 2000, turns off and flashes an f2 code occasionally. Can you give me the reason?
F2 means: For an unknown reason, the oven temperature has exceeded a preset threshold.
G.E. recommends you try this:
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code, however there are some cases when further service may be required. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737
Here is the fault code guide link:
http://www.geappliances.com/search/fast/infobase/10009792.htm
May 20, 2010 | GE Kitchen Ranges
My GE profile gas range jgbp79wewiww the clock blinks f-2 and i have to light the burners with a match tks for any help
Hi There
I have found the code for and hope this helps you.let me know how it goes.
F2 During Bake Control senses oven temp above 590 degrees F High resistance connection in oven temperature sensor circuit. Check Electronic Range Control (ERC) - Welded bake relay contactsThank you for writing to fix ya.
Best Regards Richard
Mar 20, 2010 | GE Profile JGBP79 Gas Kitchen Range
Baking cake and F2 signal
F-2 on your range indicates a bad temperature sensor. Please replace your temperature sensor in the oven.
Jul 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
The f2 keeps beeping. How do I turn this off
"F2" on most GE ranges is caused by a fault in the oven temperature circuit. Depending on model, this could mean a defective oven temperature sensor, a stalled (or faulty cooling fan-if equipped), or a BAKE relay contact on the Electronic Range Control (ERC) board that has welded (shorted) together. The easiest thing to start with first is to UNPLUG the range and check your oven temperature sensor resistance. The following link explains:
http://www.fixya.com/support/r393313-checking_replacing_oven_probe
If you do not have a cooling fan on your model, more than likely you have a problem with the oven temperature sensor, or the ERC bake circuit. If the sensor checks good, your ERC needs replaced.
If you have questions, please let me know. I hope this helps you.
PS Unfortunately, when these error codes appear, they usually cannot be defeated. This is a safety feature that warns (or prevents) the consumer from using the appliance in a potentially unsafe condition.
Jun 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
F2 flashing on screen of my GE Spectra oven.
Your oven temperature sensor has failed and must be replaced.
May 20, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Ge oven codes
F2 means your oven temp got too high. At least, that's what the control boards thinks. More than likely you have a bad oven sensor or bad wire to it or a bad connection somewhere between the board and sensor.
Dec 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGB920 Gas Range problem
if not post your email i will send you the service manual
Mar 15, 2008 | GE Profile Spectra JGB920 Gas Kitchen...
Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise themp always read 100 Degress
natural gas or propane? is this a brand new stove? or did this just start happening? is the gas shut off at the oven turned on? there are saftey features that shut off the gas so you dont get hurt. be carfull
Dec 09, 2007 | GE Profile JGS968 Gas Kitchen Range
Ge gas oven/ranger xl44
The F2 is the code for the board seeing a temp higher than 600 degrees. It could be one of two things. The temp sensor is out of range, extreme high resistance. If you ohm it out it should read approx 1100 ohms at room temp. The other would be a welded bake relay on the board itself. Check the temp sensor first. If you are getting the F2 in the cleaning cycle, check the temp sensor, welded clean cycle contacts on the board or both contacts on the lock switch are closed at the same time. This is for the model posted JGBP90.
Nov 24, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGBP28 Gas Kitchen Range Logo
75 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
