Question about Denon AVR-3805 Receiver
Receiver turns off, display does not turn on
I have had my receiver for over 3 years and it has worked flawlessly. Recently tho, I am noticing 2 problems - the display on the receiver sometimes, does not light up on power up (sometimes it turns on after some play time).
The receiver also shuts off without notice and the power switch turns red (standby mode?). Are these problems related? Please help. Thanks in advance.
Prakash
    President:
  • 624 Answers
Maybe, they are most likely related, but I can not be certain without troubleshooting it on my workbench.
These problems could be a fault of some solder connections being bad. Most of the time it is the power supply and amp circuit that have some very heat stressed solder joints and they need to be reflowed. The display problem may be the solder connections on the display board. You may see a pair of wires that go from the main power transformer to the display board, if I remember right, they are orange. That pair of wires should have an A/C voltage on it that powers the LCD of the unit. Where it plugs into the display board, it can have broken solder joints that need to be resoldered. It could be a problem with the power transformer, if you have a multimeter check to see if you have that A/C voltage when the display is out. See if it is the same as when it is on. That would help to determain what direction to take in troubleshooting it.
These unit are very difficult to take apart, the entire back panel must come off of it for you to take out the amp/power supply board. There are also a lot of screws in the board that hold it on the bottom chassis. Some screws go all the way to the bottom, and others go into a bracket of the chassis. The heat sink is also help on with screws that must be removed to get that board out. If you have any doubts about your skill level, you should just take it to an authorized Denon repair center as your first choice, if you have none near you, the best service center around would suffice. This is a very good receiver and it is well worth getting repaired. It would cost much more to replace it with a new one.
Let me know if I can be of further help to you.
Posted on Nov 09, 2008
TX DS989 turns off after 3 seconds
Sorry but it does sound like an Amp failure and testing the unit for other electronic component failure will be needed
Jan 03, 2014 | Onkyo TX-DS989 Receiver
Volume issues
Change your connectivity cables... and try again
May 23, 2009 | Audio Players & Recorders
Onkyo TX-SV444 problem
the shorted spkr wires probably fried the putput transistors in that channel.  Do you know how to use a Fluke  test meter on diode test
Dec 31, 2008 | Onkyo TX-SV454 Receiver
Onkyo TX-SR702 keeps going into speaker setup mode
Los amplificadores de audio del aparato estan a punto de danarse,checa las bocinas una por una a ver si no hay alguna mala.
Apr 14, 2008 | Onkyo TX-SR602 Receiver
Digital optical from DVD player produces no audio
Hi, It sounds like your receiver is still looking for audio on the coaxial connection, rather than the optical.
1. Make sure the optical connection is between your DVD player and the LD/DVD Optical In on the back of your receiver.
2. If you have a monitor connected to the receiver to show the on-screen display, click Setup from the main menu, click Input Mode, then, next to LD/DVD choose Optical. It may be set to coaxial, analog or auto.
Alternatively, choose the input source on the front of your receiver (LD/DVD), then press Input Mode button (bottom right, near the input selector) till it displays Digital Optical.
If all else fails, reset the receiver by:
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Use caution, however, as this will erase all the settings in your receiver.
Nov 28, 2007 | Sony STR-DA90ESG
Suddenly turning off
Your battery is dead. You'll need to return it to Garmin for repairs. Mine did the exact same thing. Functioned fine in the cradle - showed full battery - but shut off immediately upon removal. They know about the problem and shipped me a new unit for free.
Nov 28, 2007 | Garmin Edge 305HR GPS Receiver
Overload
try turning the unit off in standby mode then hold down the enter button and then the power button for about 10m seconds that should reset the unit depending on how new the unit is it sometimes has a digital saftey setting but i doubt that would cause it to do what you are saying
Oct 17, 2007 | Pioneer VSX-D411 Receiver
STR-DE597 Display is not visible
Try a complete RESET by completely switching OFF mains power and leaving for at least 40secs. before commencing a new setting-up procedure.
Let's know if this does work it back to normality!
Aug 04, 2007 | Sony STR-DE597 Receiver
Denon AVR-3805 Receiver Logo
185 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
