Question about Brother Sewing Machines
Brother xr65 i seem to be having a problem getting the right stitch size, my thread keeps breaking, please help
MakikiChris
  • 84 Answers
SOURCE: brother XR65 twin needle threading
hi roscoepc1.....The threading pattern is identical to single needle. The only changes are that you now are threading 2 spools of thread, one thread for each needle. The only change that I reccommend, but not neccessary, is that while threading through the tension dial, lay your threads between separate discs, and not together between the same pair of discs. Your tension dial contains either 3 or 4 discs.......please update your post if you have any further information or questions.....good luck my friend
Posted on Aug 05, 2007
SOURCE: thread keeps breaking
347 singer Bobine setting
Posted on Dec 30, 2007
SOURCE: Brother 1034D
You either have a burr on one of the loopers, or you have threaded the loopers in the wrong order. I do not have this particular serger, but with mine, if I the lower looper thread is looped above the upper one(down where they all meet), it will break. Cut your lower looper thread and re thread it making sure its above the lower looper one.
Posted on Jun 12, 2008
bibleman01
  • 334 Answers
SOURCE: CONSEW 206RB5 TOP THREAD NOT FORMING STITCHES AND BREAKING
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Posted on Jan 18, 2009
  • 9 Answers
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
Brother750e in-no is dowloaded photo transferred to stitches using foil thread or embroydery thread , top thread keeps breaking, I've changed the needle don't know what else to try . Please help
Metallic thread is often easier to break when sewing. Make sure the thread is not brittle and old; It may also require "Metallic Embroidery" needles that have a slightly larger needle groove and eye spaces. Also, make sure your thread does not have additional tension on it when being fed from a vertical spool. allow the thread to flow horizontally off of the thread spool into the machine.Or place the spool bottom down on the table next to the machine and let the machine pull it up and over through the machine which needs to be very properly threaded.
Cheers,
Embroidery Services
San Diego, CA
Jul 09, 2016 | Brother Sewing Machines
Brother Innovis 1e isn't stitching properly when the feed dogs are down
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem.
Nov 25, 2013 | Brother Sewing Machines
Tangled thread on wrong side. The thread on the
I'm guessing it is because the tension is not just right, the bobbin might not be the right size, the thread type top and Botton might not be the same, or you just might need put in a new needle the right size.
Aug 09, 2017 | Brother CS-6000
The bobbin thread keeps breaking
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Jan 21, 2013 | Brother Sewing Machines
I keep having problems with the stitching on my machine. 1) when you sew the stitches looks normal from the top but when you turn the material over it looks like one big tangled mess. 2)When it does...
It is usually in your top threading, make sure that your thread match in bobbin and top threads. Mixing sometimes causes a problem. Also make sure that nothing is tangled. Also, check your needle and put a new one in just to be sure, then check your manual for size of needle and what kind of project you are doing. Hope this helps.
Sep 26, 2010 | SINGER 7470 Sewing Machine
My lowerlooper thread keeps breaking. I can only
The lowerloop thread kept getting cut by the upperlooper.....I rethreaded the machine in order and then made sure that the lowerlooper thread was UNDER the part of the machine that makes the looks the loopings (silver part that comes to a point on the right side of the needles...sorry I don't know what to call it) and the upperloop was ON TOP of the same part.....it started working great. I actually have very nice tight stitches now.
Jun 19, 2009 | Brother 929D Mechanical Sewing Machine
Cannot machine quilt without the thread breaking and/or shredding. I've change needle, thread type and size and tension on my fabric.
If the thread is shredding and breaking, there is an incompatibility of your needle, thread, and fabric. Could be old, bargain bin, or poor quality thread--does the thread have little "hairs" of thread lint sticking out of it--that's probably not good quality. Look for fresh, good quality thread. Try a brand new needle--a sharp if you are sewing woven fabric. Make sure the thread is not too big for the needle eye. Sometimes, a top-stitch needle or embroidery needle will work well on FMQ. (A top-stitch needle has a longer scarf which helps protect the thread during the multiple times the needle penetrates the fabric before the thread forms a stitch. Shredding means the thread is getting worn out before it forms a stitch. A piece of thread penetrates the fabric 10-20 times before it forms a stitch.) Could also be a snag somewhere that is damaging the thread.
Sewing Needle Troubleshooting Guide
SCHMETZ Household Needle Chart
Most FMQ instructions say the upper and bobbin tension should be the same, however, I find my machine works a bit better when the bobbin thread is just a little tighter than the upper thread. Then the bobbin thread does not "pop" up on the top of my fabric quite as much. It's probably something you will just need to experiment with in getting used to your machine.
P.S.--when threading your machine, make sure the Presser Foot is ALWAYS RAISED so the top thread will seat properly in the tension disk. Failure to do this will cause thread barfs (usually referred to as thread nests or bird nests) under your fabric. Also, before beginning your FMQ, ALWAYS PULL the bobbin thread to the top of the fabric, then hold both thread tails gently in your left hand while you slowly take the first couple of stitches.
How and Why to Bring up the Bobbin Thread
Mar 01, 2017 | Brother Sewing Machines
Brother LS-2125 Upper Thread Snapping
I had the same problem and it was so frustrating! It was happening to me because I wasn't using the right size needle. Go up a couple of needle sizes and see if that helps.
Feb 12, 2009 | Brother LS-2125 Mechanical Sewing Machine
Thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Dec 16, 2008 | Simplicity American Denim SA1100...
Brother Embroidery machine thread keeps breaking
It doesn't matter so much the thickness of the stabilizer but more a matter of it being taut like a drum and the proper stabilizer for the fabric you're using. Couple of reasons the thread breaks...the thread gets caught on the edge of the spool in the crack where the thread originally starts, you're not using the right size spool cap or the upper thread is wrapping around the spool pin. When I use my 170 for embroidering I always use the vertical spool pin to eliminate this problem. Try it and let me know how you make out.
Nov 18, 2008 | Bernina Artista 180
Sewing Machines Logo
57 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
