L tec pcm100 machine seems to be normal but when the trigger is activated the high frequency arc comes on and then stops. If the arc starts it pulsates and stops.
  • 1 more comment
  • ronlovrich Nov 04, 2008
    no error lites 10 yrs old no help!
  • ronlovrich Nov 05, 2008
    No help This machine is a plasma cutter not a tv!
    Then send my money back!
  • 728 Answers
You may have a short on the main board causing it to only arc once and then go into auto shutdown mode to prevent the whole thing from catching fire. But first make sure you have all of the parts you are supposed to have or else it will not work properly. You can use this site as a checklist and for more information: http://www.abicorusa.com/AbicutCat.pdf
If this is not your problem, then check and see if is under warranty and send it back to the shop. They will check it and tell you what the problem is and they should be able to fix it for free.
Posted on Nov 05, 2008
  • 535 Answers
Then u have to go any industrial profession service in plama cutter there is a michenical probem
    Brigadier General:
  • 6,966 Answers
This is a specialized power supply (either for single or dual gas). Due to the nature of the design, it is highly recommended that the manufacturer or their authorized service center work on the unit. Other than checking the connections of the torch package and/or the hookup kit, there are no other user serviceable. An alternative is to reference their Download Library or secure a copy of the Service Manual and/or consult with ESAB AB, the manufacturer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 04, 2008
  • Louie  Role
    Louie Role Nov 04, 2008
    Incidentally, if you are located outside of the United States, pls start here.
    Genius:
  • 1,913 Answers
Try to change resolution
reset your device press power button for 10 seconds.
aslo check power supply adapter and earthing working proper .
try to changwe power sourece means power bord of your home.
check with another place.
    Brigadier General:
  • 3,614 Answers
Did you got any error light indicators on the machine appears with this problem. how old is the machine w?
Posted on Nov 03, 2008
  • micromaster
    micromaster Nov 04, 2008
    this could be the problem on the mainboard. it better to check on the convergence area.
What polarity do I use for tig welding aluminum, and what color electrode for miller hf-p dial arc
Jackie, watch the linked videos on tigging aluminum. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 31, 2016 | Miller Welding Tools
I have a accurate tools 3n1 stick,mig, and plasma cutter everything works except the plasma press the trigger air comes out but no arc at all on tip to metal can hear the relay clicking when switch between...
Could be as simple as having the ground cable connection placed into the wrong port on the front of the machine. Foot peddle/machine selection switch in peddle mode instead of machine mode? Internally it could be high frequency spark leakage or failed HF circuitry. These are the most common causes of spark failure. Oh and be sure you have good consumables and they are installed correctly. Air pressure leaving the torch head should be around 70 psi.
Aug 27, 2014 | Welding Tools
My tig welder wont arc unless I touch the metal with it
my guess would be the type of welding machine you have.usually there is extra switch which says start control also continious cycle , sometimes smaller machines dont have these switches to allow a wider variety of tweeking the welder ,also its ok if you have to touch the base metal cause thats what starts the contact with the work peice ,keep a arc after touching about 1/4 inch away from work peice ,also a good steady hand rest will make a good welder in any situation this should allow the arc to remaim stable with a comntinious weld arc puddle. happy welding
May 22, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Solar welder 2175 wire keeps feeding wont stop doesnot arc until trigger is pulled
Look on the front pannel. thier should be a "latching Switch" indicated by "4 X 2" little arrowes. The 4 is " pull the triger -- the release the arc continues, the "2" is pull the trigger and the arc startes release the trigger the arc stops simplesssssssss
Ken
Dec 14, 2009 | Welding Tools
Arc starter on sync 350 interferes with equipment
It's the high frequency, ground the case of machine, work lead connection and work table, do not chain grounds together, this will cause a ground loop.
Jun 25, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
No arc. Power and Air OK
if the main power cable is cut that is your problem,unit uses high frequency.the two leads go to the gun trigger back to unit,no fuse or fuseable links in the gun.
May 13, 2009 | Welding Tools
LINDE HDA 300 TIG WELDER HIGH FREQ. PROBLEMS
The contact should have a gap .008 .
Mar 21, 2009 | Welding Tools
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
