Sony Cyber-shot  DSC-W55 Digital Camera Logo
Posted on Nov 03, 2008
My camera just shows a black screen and the orange light flashes
My daughter dropped the camera several times . Now, when you turn on the camara it only shows the black screen and the orange light flashes for some seconds. I cant review pics, use the menu or taking pictures. What could i do to repair it?
  • 1 more comment
  • Anonymous Nov 06, 2008
    black screen
  • yjfdghgfd Apr 27, 2009
    ryere
  • lynden2007 Apr 28, 2009
    after one year of use. It just dont light up anymore.Only black screen. Tried a new battery still no help.
Anonymous
Level 1:
  • Contributor 49 Answers
  • Posted on Nov 06, 2008
Anonymous
Contributor
Level 1:
Answers
49
Questions
5
Helped
38899
Points
86
Nothing unfortunately...
unless you have a thourough knowledge of digital cameras and the equipment i dont recommend attempting some DIY work...
if its still in warranty send it to the manufacturers and hope they will take it and fix it!
the other option is to take it to a professional who specialises in digital cameras, do not leave it with them without making sure you trust them though.
Good Luck
A
Anonymous
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
My daughter vomited on my Canon PowerShot SD750 (Black)???
Get an estimate of the repair cost and then decide whether to get a new one or not.
L18 Camera comes on but have a blank screen in All modes
i have the same camara i drop it and the screm is brokend can someone fix it
On my HP 537 camara my daughter dropped it now the switch that makes the camara go to view pictures or take movies will not work, it just slides back and forth? Is there a way I can open it and fix the...
If you can take things apart without damaging things...then it may be possible to fix. I have had mine apart several times, and the slider on the outside, switches a mini micro slider inside. It has to be lined up with the tabs...dropping it may have caused it to jump the slots.
Flash
I gave the lense part of the camara a moderate slap, and the camara has worked fine since. looks like a lot of people have the same problem. Most of the people call it black screen problem. the shutter gets stuck. Tap it a few times on the side of the lense part of the camara moving it from bright to dark objects back and forth.
good luck.
2answers
LCD Screen help
How do you get the camera back to the original settings
1helpful
3answers
Problem with lens
It is possible you have the display turned off... Some cameras allow you to do this to save battery.
Black screen; like no other problem. ;P
OK, as crazy as it sounds, give the came a few good whacks on the side. It seems like there's internal problems, but it got my camera working. Do I get my money now?
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
