Question about kawasaki Full Suspension Mountain Bike Men
Kmx 125cc 1990 model
I hav just put on led indicators they just stay on but dont fliker i hav put on resistors aswell but nothing
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi
    What value of resistor have you used??
    regards
    robotek
    New Friend:
  • 41 Answers
Hello, double check for a good ground
Posted on Nov 25, 2008
Hi there I have a kmx 125 with a 200cc head, barrel and piston just wondering what the difference between a kmx 125cc carb and a 200cc carb
This venturi (throat) size and the jet size are different...the smaller carb will give more bottom end.... the larger carb will make it run better mid range and top end...
BOTH must be jetted correctly...by someone that knows how!!
Aug 29, 2017 | Motorcycles
I purchased led turn signal lights for my yzf600 and they work but dont blink and also they turn off my front turn lights. i took out the indicator signal bulb and it still did not work
you need to get a relay to suit L.E.D lights, and as far as I know, you will have to run L.E.D lights(indicators) on the front aswell as the rear.
Dec 06, 2012 | 1997 Yamaha YZF 600 R thunder cat
What oil do i put in a kawasaki kmx 125?
hi my kmx 125 runs starts fine but when i put it in gear it cuts off help
Nov 08, 2012 | 2002 kawasaki KMX 125
My problem on my kawasaki fury 125cc is the cluth timing
http://www.repairmanualclub.com/motomanuals/index.php
Feb 24, 2011 | 2001 kawasaki KMX 125
Indicators dont flash aftermarket rears have been put on replaced the relay and still the same
what kind of lights were on it before? if they were regular bulbs before and now you switched to LED you need to install resistors because LED's don't require as much voltage.
May 20, 2010 | Motorcycles
GS500e 2005 with indicator problems please help!!!
Sorry to be the bearer of bad news but you are going to have to take your machine to a auto electrician to sort it.
You will never in a million years get a online diagnosis following your attempts to fit resistors and diodes, god only knows what damage you have done. May this be a lesson to you, If you don't know what you are doing leave it to the professionals.
Aug 21, 2017 | 2005 Suzuki GS 500 E
I would like to have complete wiring diagram for kawasaki kmx 125
http://bikeforum.comxa.com/Forum/motorcycle-owners-manuals/kawasaki-kmx-125-service-manual/
appreciate it if you sign up
Sep 24, 2009 | 2001 kawasaki KMX 125
LED Indicators
or can I disconnect OEM indicators and connect one up to see if it works ok. Basically I dont want to rewire the bike for the indicators not to work!! just installed my LEDs a couple months back. All I did was to change the flasher relay that you can buy at local auto store for less than $10 bucks. and add resistors inline that are 8ohm 25watt. You can get the resistors from radio shack. i only needed to install the resistor on the front indicators. I didn't do them all at the same time. So, the rears worked fine with just the flasher relay for me but depends on your LEDs. Be safe and just get the resistors and relay and all will work just fine. And you don't need to rewire your bike. ....The problem is that the LEDS do not pull enough power to trip the relay to flash and the resistors correct that. And do them all at once..,,,
Nov 10, 2008 | 2000 Aprilia RSV Mille SP
BROTHER HL-2040 LASER PRINTER- TONER LED INDICATOR STAYS ON AFTER I REFILLED THE TONER
Dont recomend refills causes too many problems, like you are experencing, put in a real brother toner should fix problem.
great link to explain of lights on panel
Dec 18, 2007 | Brother HL-2040 Laser Printer
kawasaki Full Suspension Mountain Bike Men Logo
90 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
