Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Ge cabrio error codes
The error code comes up after one minute of water filling cycle
  • mikedease Nov 17, 2008
  • Anonymous May 03, 2009
    I am getting an F50 error.
Posted on Feb 20, 2009
  • 3 Answers
So what is the error code?
Posted on Nov 15, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Lf code comes on twice during clean cycle and I have to press start button to get it working again
Ok this error means Long fill as you know, Basically if the machine has not filled after 10 minutes then it goes into this error condition. First thing to do is make sure the taps are turned on, they likely are so unplug the machine, shut the taps off then unhook the water lines at the rear of the machine, next look inside the vlave (where the fill pipes hook up) and check the filter screens, these are likely clogged.
Jun 27, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
After a cycle starts a code comes up "F"
Long fill? Try cleaning the screens on the water valve.
Dec 27, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio top loader that hums initially when a load starts. i beleve this is during the water in cycle time but not sure. no error codes displayed. Washer works fine otherwise. any ideas???
Yes that sounds right a hum would be at start of cycle if water flow into was restricted in some manner and washer wasnt filling. What your is the hum the water valve makes when is calling for water yet no water from hoses coming to it.
The things to check are for blocked filter screens inside of ends of water valve on back where hoses attach to.
If you have :AQUAFLOW" brand hoses the internal stopper is hose is bad and hose should be replaced using standard hoses
Also for water coming from house pluming where hoses connect to at wall/faucet/spigot
Aug 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a GE Harmony Profile top load washer. It is stuck on filling during the rinse cycle. It usually stays at 18 minutes for about 15-20 minutes. I usually start adding buckets of water to get it going....
when washers go into rinse cycle they use cold water so the clothes don't rinkle,i would say that you have a bad water valve located on the washer,you can try to run the wash at the beginning just with cold water,if the water comes in slow you have a bad valve,you can then run it on just hot water and see if there's a difference in how fast it fills.the strange thing is that it should pop up with an error code after 6 or 8 minutes because the washer is filling to slow,have you seen any codes come up?if it is the valve the part number is WH13X10017 and that valve is under the top console
Nov 10, 2017 | GE WPGT9360EPL Top Load Washer
Whirlpool Cabrio: During a white load the machine stops at 38 min
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
May 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio washer is leaking water
The problem happens when your installer throws away the drain hose u-bend, and stuffs the hose as far as it will go down the drain pipe. When this happens the end of the hose can get pushed under water, which causes the washer to siphon out the wash water when it fills. This results in an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio washer
Sounds like a control board problem
Nov 11, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
799 people viewed this question
Dan Webster
Dan Webster
Sal De
