Question about NorStar T7316E Corded Phone
Setting the speed dial numbers
Please could you let me know how to programme the speed dial keys from 1 - 20, have done it before but can't remember how.
Thanks
Dial Feature *4
Enter the speed dial code (71-94)
Press a line button or a pool button
Dial the phone number desired
Press hold or OK to finish
Posted on Nov 19, 2008
BCM50 3.0 can only program external speed dials from the main phone but cannot from any other phone. Has many one heard of this problem?
Posted on Sep 10, 2009
Could you please tell me how to programme numbers into my speed dial as i have lost my manual
hi friend, go inside call setting. there is an option speed dial.then, select a particular number. select option to select contact . which you want to assign in.
then, come back to dial up keypad. and press that number for few sec. then, automatically call is dial to that person.
Regards: Rakesh
Feb 16, 2011 | Cell Phones
Setting speed dial
WITH A DIAL TONE Present: Press "Program then tap in the number you want to save then press the Speed dial button you want to save to (remembering each button has two numbers so, if you want the bottom spot, press the toggle button first) and you are done
Nov 16, 2010 | AT&T 982 Corded Phone
How do I programme the memory on an answercall sp100 phone?
1. Pick up handset OR press 'handsfree' and wait for dialling tone.
2. Press 'store'.
3. Dial number you wish to put in the memory.
4. Either press 'M1', 'M2' or 'M3' to save as one touch speed dial numbers OR press 'store' again and then press any number between 0 - 9 to save two touch speed dial.
5. Replace handset and you're done.
In future if you wish to dial a one touch number then so long as you remember which button you ascribed to it you can do so with M1, M2 or M3. If it was a two touch number then you will need to press 'memory' followed by whatever number you ascribed between 0 - 9.
Hope this helps!
D. Nisbet
Sep 12, 2010 | Cell Phones
How to program the programmable keys to an external number
The programmable key has to be an SPD button, you then enter the speed Dial entry number. To do this go to Youtube and follow the training video which I have loaded for you, this explains MMC 722, you must have that specific phone number in the speed dial directory, again this can be found at Youtube search 'abbeytel'
Dec 14, 2009 | Samsung Phone PDCSLCD12B
How to program speed dial numbers?
To Set:
Do not lift handset
Press FNC button
Press the desired “One Touch” Key
Enter number to be stored (remember”0” for external numbers)
Press FNC button to save
To Dial
Lift Handset
8
Press desired One Touch key to dial
Jun 25, 2009 | NEC ETJ 16DD-2 Corded Phone
Re-programm speed dial keys
Sorry delete it/them and reprogram. Carl
Jun 10, 2009 | Ricoh FAX2900L Plain Paper Laser
Programming speed dial numbers into NEC DTU-32D-1A phone
hit feature key,hit a line key,dial 9 plus the number,hit feature
Mar 12, 2009 | NEC Electra Elite 32D-1 Corded Phone
Programmed speed dial - internal calls
To add an Extension Key: -
DONT lift handpiece, enter [*91] then press a vacant memory key and then choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
To dial an Extension Key: -
Lift handpiece.
Press the memory key you programmed.
Storing a personal speed dial number: -
Lift handpiece.
Dial [*92]
Dial memory number.
(*0 - *9 for personal numbers)
Press the [ü] key.
Dial 0 then the number to be stored.
Press the [ü] key.
Hang up.
How to dial speed dial numbers: -
Lift handpiece.
Dial [*7]
Dial memory number.
(001-999 for system numbers)
For Example: [*7*0 ü] will call the personal number stored under position *0.
[*7001 ü] will call the system speed dial number stored under position 001.
Jan 19, 2009 | Siemens optiPoint 500 Standard Corded...
Need manual for SBC Freedom Phone Model HAC FC2548
to programme speed dial just go to contact on your phone menu and select the conatct you want to speed dial and assign speed dialing number for the person or you type any number on your phone and press the harsh key like this (10#) and it will bring out the number assign to that spedd dial
Dec 15, 2008 | Southwestern Bell (S60802)
Clear speed dial/one touch settings
There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
Aug 13, 2007 | Panasonic KX-T7431 Corded Phone
NorStar T7316E Corded Phone Logo
1,364 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
