Question about Frigidaire FRS26R4A Side by Side Refrigerator
Frigidaire side by side
The water dispenser in the door comes on by itself and pours water all over the floor.
  • 2,692 Answers
Is your water preasure high where you are located? You may have to put an expansion tank on the main line or an expansion chamber on the water line leading to the refrigerator. To check or confirm , have some  a faucet off and on quickly.    Barring that , the water control valve spring has gotten weak and you wil have to replace the whole valve.
Posted on Dec 25, 2008
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
I have a Frigidaire GHSC39EEPW1 side by side with ice and water dispenser in the door.It keeps dispensing water by itself.It even does it when locked.What could be the cause of it
Hi Steve Garner - There are a couple of factors that can cause a side by side dispenser to dispense water by itself. The refrigerator could possibly have a faulty valve, dispenser control board and/or failed water valve diode. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
Mar 03, 2013 | Frigidaire FRS26R4A Side by Side...
No water going into door for dispensing or ice maker mod# MRS26LJ
I'm not sure what you damaged with heat but- Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws OR
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 08, 2009 | Frigidaire FRS26H5AS Side by Side...
Water pouring from waterdispenser in side by side refrig
Dispenser leaking----Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser
Jul 01, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Water accumulation in bottom of freezer in Frigidaire FRS26ZSHB5
take out everything and at the lower inside back of the freezer you have a drain ..... pour hot water till it opens / the water comes from you evap when it goes into defrost and it cant get out the drain / Larry
Nov 25, 2008 | Frigidaire Refrigerators
In door ice and water dispensing
sounds like the paddle is hanging up or the micro switch that the paddle actuates is sticking if you can see the micro switch spray some wd 40 on it open the door and work the paddle a few times
Feb 15, 2008 | Frigidaire FSC23F7D Side by Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Ice dispenser comes on by itself.
you need to replace the dispenser selector board.
Sep 03, 2007 | Frigidaire FSC23F7D Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
93 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
