Question about Hotpoint FFM90 Bottom Freezer Refrigerator
Fridge motor is very very noisy
When the motor kicks into gear it makes a lot of noise - this is only a recent problem and the fridge is only just over 2 years old. When the fridge door is opened after it start making the noise you can hear the motor struggling and chocking.
  • 1 more comment
  • gtf7 Nov 10, 2007
    Hotpoint Fridge. Motor has started to make very loud noises. Stops when fridge door is opend but worse when freezer door open. Unit is just over two years old but has just recently fully loaded the freezer. Could freezer have been over loaded and this damaged the motor? Could it be some other problem?
  • Anonymous Nov 18, 2007
    Exactly the same problem. Numerous engineers and no solution. Inherent design fault. Avoid purchasing again. Our solution is to bang the back panel from the inside of the freezer - which works temporarily!
  • Anonymous Mar 18, 2008
    my fridge motor is makes sounds like a tractor put put putting along ,seems to run longer , fridge and freezer are still cold , but it shuts off it goes clunk clunkclunk, so i pretty sure it the motor , took the back off and does not seem hot, fan was running but the noices were coming from the black round contained thing, could you pleasse help me should i call a repair man, or should i just buy a new one, don't really have a lot of money right today. thanks MEGAN, I live in alberta, canada. 1-403-340-8208 or e-mail me - m_leptich@hotmail.com fridge #MOD=KTRS22KHWH00 SER#EKO532170,, MFG. DATE= 01-00
    Novelist:
  • 75 Answers
It sounds like it could be ice around the fan motor. Unplug it and let it defrost for about 12 hrs with the doors open. Plug it back in and see if it has quit making the noise. If it did it probably needs the defrost timer replaced. Good luck. kstfas
Posted on Sep 29, 2006
    New Friend:
I had this fridge freezer with the same problem, it's quite easy to fix. Switch off, remove but do not unpack the freezer drawers (insulate them in a cardboard box) then remove the rear panel in the freezer compartment. Remove all the ice you find; try thawing it with steam from a kettle. Also, if the drain is blocked with ice you can get access to it the same way, try pouring in hot water to thaw it. To remove the freezer compartment panel you need a socket 6mm I think. With the right tool it only takes about an hour start to finish.
Posted on Apr 24, 2013
Has anyone tried this solution??
Posted on Jul 27, 2008
My new black glass double door fridge and freezer is so noisy it actually wakes me up.Please help.Les
Les,
The nature of the noise can tell you a lot. Is it a smooth compressor sound that is excessively loud? Is it metallic like a fan blade might make if it is hitting something? A squeal like a failing bearing might make? Is it constant? Intermittent? Has it always been there?
I assume the fridge, other than noisy, operates correctly and normally.
You can add acoustic foam to reduce the noise (Find "Black Hole" acoustic absorbing foam or similar). If doing this, you cannot impede the airflow to the heat ex-changers or the compressor motor, or you could drastically shorten the life of your appliance.
You should also try and divine where exactly the noise is coming from. Lacking a stethoscope, a 1/4 " wooden dowel, placed against various areas on one end, and the other on the little skin flap of your ear, will safely telegraph mechanical vibration to your ear, allowing you to localize problems. Once you know exactly where the sound is coming from, it may be easier to correct the noise.
Mar 17, 2018 | Refrigerators
NOISY FRIDGE
hi glenn ,most fridges make this noise but if your worried ring the place you brought the fridge from and get them to send an engineer to check it. good luck
regards
shaun
Dec 09, 2011 | Washing Machines
Westinghouse virtuoso fridge is noisy after leaving the freezer door open several hours
First analyze from where you are getting the sound.
1)Check the fan at the back side of the freezer.Is it making noise.Remove it and put some oil so it will rotate without sound.Check for the bending and straighten it and see it
doesn't hit on body.
2)compressor motor may vibrating a lot making noise to the condenser coils.It makes the full fridge to vibrate and makes noise.Adhesive stickers will soften them.If still problem persist coil could be damaged.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 06, 2010 | Refrigerators
My fridge has become very noisy? Could you advise?
The fault can be the vibration of the compressor motor radiating the noise to the condenser coils. So it may be hitting against the walls of the fridge and you are getting this noise. Also tthe compressor makes tteh vibration that transmits to plastics, trays at the bottom of fridge and the rear mounting. Use good adhesive stickers to soften them.
Aug 30, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
My fridge has become increasingly more noisy when the compressor kicks in. Any thoughts on why and how to fix this?
The only way to eradicate the noise, is to replace compressor. Some make shuddering noises on start up and some on switch off. Basically, in the compressor dome are 4 rubbers equally placed holding the internal motor. If one of those rubbers disslodge, then the noise starts.
Jun 05, 2010 | Whirlpool ES5FHAXS Side by Side...
Noisy Aga fridge
where is the noise? inside or outside? inside maybe the evaporator fan motor. hitting somethig> wire . get a tech to double check not dangerous. outside. noise compressor dont replace. have to live like that or replace the whole fridge. or condenser fan motor. call atech for replaced
Mar 30, 2010 | Refrigerators
Whirlpool fridge incessant buzzing
The knocking noise when cuts off , is a compressor internal motor support spring , broken . This does not mean the compressor is bad , only noisy for the rest of the compressor life , but should be covered under the 5 yr warranty . The gurgling sound is the refrigerant being pumped thru the system . The buzzing could be from the compressor also . My suggestion , would be to call a factory warranty company , to see if they can replace the compressor under warranty .
Sep 07, 2009 | Refrigerators
Noisy frig
it could be that your cooling fan gets noisy at times and stops for a while you could try to put oil on the shaft behind the fan this will help when it does get noisy pull the fridge kisten to the motor if noisy replace it its not to expencive about 40.00 dollaresthanks from gilles
May 12, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Open Questions:
See all Hotpoint FFM90 Bottom Freezer Refrigerator Questions
Hotpoint FFM90 Bottom Freezer Refrigerator Logo
1,992 people viewed this question
Top Hotpoint Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
