Error code SC-481 on a ricoh/aficio 1224-c - Office Equipment & Supplies
SOURCE: Ricoh aficio 450 error code
set key counter plz
Posted on Oct 31, 2008
SOURCE: Have a Ricoh Aficio 3025
ERROR SC 548
Posted on Nov 07, 2008
  • 126 Answers
SOURCE: sc 481 on my ricoh aficio 1224
moz-screenshot.jpgmoz-screenshot-1.jpgThe problem (s) could be; defective main motor, image transfer belt out of position, belt mark blurred or absent.
A ITB belt inspection and/ or repair would be a job for tech.
Or you could just order a new PCU which would fix the problem.
Posted on Jan 08, 2009
SOURCE: SC350-01 error code
Probably just a dirty "ID sensor". If you remove the drum (carefully) and set aside. Open the right cover, and towards the back of the machine above where the drum sits there is a small LED sensor mounted pointing down toward where the drum sits. Clean this with a tissue, put back drum and try.
If this fails, then the sensor is bad (or broken wire), or there is a circuit board problem (serious). Either IOB board or High voltage board.
Hope this helps.
Please rate solution
Posted on Apr 23, 2009
  • 34 Answers
SOURCE: continual communication errors with Aficio
Turn on or off your error correction to see if it changes also try changing your phone cord.
Posted on Mar 24, 2010
Testimonial: "Thanks - appreciate the assistance"
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
I have a ricoh 1224, and is displaying a 'functional problems' notice. Is there a solution to solve this?
What is the exact error code that you are getting? There should be a code displayed on the screen, starting with "SC" and ending with three numbers. Those three numbers will determine what the exact problem is. Depending on the code, it may be something easily fixable, but if it requires replacement of any parts, you may be out of luck -- the 1224 is an old printer, and it may be difficult to find new parts for it.
Aug 18, 2011 | Ricoh Aficio 450 Copier
Error sc 481 en ricoh aficio cl5000
defective transfer belt. make sure that it is properly fixed.
Source
May 20, 2011 | Ricoh Aficio CL5000 Laser Printer
Ricoh aficio cl1000n sc481 error message
sc 481 is the OPC belt error. check the opc belt unit. it is also called rum unit. i think the belt is worn out and needs replacing.
Jan 06, 2011 | Ricoh Aficio CL1000N Printer
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Sc 481 on my ricoh aficio 1224
Jan 08, 2009 | Ricoh Aficio 2015 Copier
47 people viewed this question
jasbo
jasbo
