The power light is off and just the two right bottoms are blinking with red lights and in computer show general error , turn off your printer and again on.
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Clean "left area"
of "Front paper guide Assy"
Ink $ dell light both light blinking
Unplug the printer and plug bag in. power up the printer. restart your computer, then try to print again.
if the printer won't power on at all. try clicking all the buttons on the printer, including the red blinking ones. one at a time. if this desn't work, turn off computer, search for the computer's driver software online and download it and reinstall it on your computer, following ALL directions. keep printer plugged in to your computer while your doing this
Steps to Solve Printer error turn power off and then on again in Epson Printer
Step 1:- Turn off the Epson Printer
You should try to unplug the power cable from the wall outlet for nearly 5 minutes. Then power "ON" the Printer again. Check the error is resolved. If the error has not gone, then follow next solution.
Step 2:- Store the Transportation Lock
Make sure that the transportation lock has been removed.
Step 3:- Ensure that CD Tray Is In the Eject Position
If the CD tray is ejected position, make sure press CD tray button to retract the tray with storage position. Never forcefully pull or push the CD tray into position.
Step 4:-Ensure the Paper Is Not Jammed
Turn off the Epson Printer and make sure the paper is not jammed inside the unit.
Step 5:- Ensure the Epson Printer Carriage
In case user Epson Printer with CISS installed to make sure the printer carriage can go left and right smoothly.
Step 6:- Verify the Upper Scanner Part of Printer
Make sure that the upper scanner part of your Epson printer is locked or closed tightly.
Step 7:- Check the Entire Units Function
Initialization routine that gets run on startup checks the entire unit function before completing without an error.
Step 8:- Install Original Epson Ink Cartridges and Run the Printer
If you use CISS then there may be ink tubes preventing to move the carriage from left to right. Then it's recommended for you to install original Epson ink cartridges and run the printer. If there will be NO error that means the reason is the CISS-installed not correctly.
Step 9:- Move the Carriage
Now you need to access the cartridge loading area while off and then move the carriage away from stops just an inch is needed. Next, lifting slightly, make sure that it must move easily. If it appears sluggish at first the ink collection cup is gummed up and needs cleaning.
Step 10:- Clean all Optical Sensors, and Printer
In case the paper path has a sensor that is mounted opposite the size is adjustment slide on the paper tray. Typically a small opto-sensor it can be blocked with dust. The best solution is to disassemble the printer and clean all optical sensors, paper feed sensors, encoder strip, and disc encoder.
I hope the issue is resolved.
If You Still Face the Problem Do Visit Us: Printer error turn power off epson printer
Toll-Free No:
USA- +1-888-633-7151
My Epson T50 printer is giving general error. And I try to unlock the print car turned on the gear and it will not unlock. Detail the printer had long time standing still. Art Gesso Placa de Gesso 3D Servios
SOURCE: Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
SOURCE: two red light blinking
Do you see any flag message like " end of service life-------". You should find a resetter for the printer, its a utility program.
Or its a paper jam, or dirty ink chip connector.
SOURCE: c43sx both lights on
my printer epson stylus c43 series have a problem... the red light was blinking....
SOURCE: Epson stylus D88 - blinking red lights
this means that your printer need to be reset this should work http://www.ssclg.com/epsone.shtml
SOURCE: epson stylus c42 plus
If both red and green lights are blinking, it usually means that your waste ink pads need replacing. This requires dismantling of the printer and resetting of the protection counter. If you feel up to it, respond with your e-mail address and I will send you instructions - but it's not easy.
