Question about JVC AV-27530 27" TV
Brightness (hellllpppp!) My JVC AV-27530 seems to be dark all the time. I have tried menu options but makes no real difference. I was looking at the back of it to get inside and clean it up and there are the normal screws that hold it on plus 3 or 4 small screws around the jacks. My question is: if I pull those small screws (i assume i must) is there a circuit board that is going to drop off inside my tv? and is it going to be a pain in the butt to get it back on? Thanks, mooserny
  • CHRIS MOUSAW Sep 29, 2006
    Thanks, I just fixed the problem took like 30 sec.....lol. I found a posting from techman about adjusting the transformer and it is now working fine. So a large thank you to the techman.
    Thanks again,
    mooserny
    Sergeant:
  • 337 Answers
To answer your question nothing is going to drop inside the set,I also need to tell you that a cleaning of the inside is not going to correct the problem,you should get at least the opinion of a servicer to determine if the set is repairable or not,an experianced techician should have a very good idea as soon as he sees the picture,if he sees the need to remove the back cover that will be a good time for you to see if it needs cleaning,Be safe and get an estimate.
Posted on Sep 29, 2006
How do you adjust the brightness of screen internally
On most , it is adjusted on the G2 control
marked "screen" on the Flyback Transformer
Sep 09, 2012 | JVC AV-27530 27" TV
Our tv has been getting darker and darker - we've tried to adjust brightness in menu and have it set to far right but its still too dark. Is there another adjustment to brighten the picture other than...
In many many cases this is an indication of a failing picture tube. The gun assembly in the neck of the picture tube is shorting. There is a fix, but this is surely last resort and the final cure may not provide a fix. Picture tube rejuvenation is not always successful. I would certainly opt for a new TV. Thanks for asking, and show a few hands of support!
Mar 13, 2011 | JVC AV-27530 27" TV
Picture on tv JVC 27" AV-27530 is getting to dark to enjoy. During dark scenes you can't see much. Have tried adjusting controls and settings to no avail. Any solution greatly appreciated.
I have the AV-27S33 model and in the rear to the right of the inputs are two slits and inside these slits are two screws. The top screw is the focus,the bottom the brightness.Your tv is a different model but it may have this same adjustment,if it does try turning the bottom screw to the right to increase the brightness.
Jun 11, 2010 | JVC AV-27530 27" TV
I have a JVC 27'' AV-27530 TV that the picture is very dark
An aging FBT if it still can be adjust using screen adjustment on FBT that will be a small tweak.
But if you are inexperienced with this, asked someone who knows how to do it to fix it for you.
Apr 08, 2009 | JVC AV-27530 27" TV
Picture getting dark
My jvc 27" tv was so dark I could hardly see any night scenes, even with the bright all the way on. If you push the sleep button, let go, then hold down the video and display (together), the service menu will come on. Scroll down to #7 (too dark) and adjust the brightness there. Works immediately. Good luck.
Nov 29, 2008 | JVC AV-27530 27" TV
Picture is too dark
How many years is your TV now? Usually TV has its life span, there comes a time that it happens. And need to look for a technicians, cause some of theme can still be repair by adjusting the brightness inside your TV.
Oct 19, 2008 | JVC AV-27530 27" TV
Jvc av 27530
**WORKS**
In my case, the adjustment was available from outside the TV. Sortof. On the rear of the TVabout 2 inches to the right of the coax in, there are two vertical slits on a little protrusion. Inside the slits are the two adjustment screws. The lower screw adjusts brightness, the upper screw adjusts focus.
Dec 23, 2007 | JVC AV-27530 27" TV
JVC AV 270305 Brightness not Bright enough.
Yes you could look for the capacitor that is leaky, probably in the 200v line, or you could just open back and turn up G2 screen control on the Flyback. You have Screen and Focus on this black transformer with a long anode lead going to the picture tube of set. Becareful, High Voltage!
Sep 08, 2007 | JVC AV-27530 27" TV
JVC AV-27530 Sudden changes in brightness
This sudden changes in brightness are caused by the change in voltage inside the tv,not in the outlet in the wall but inside the set,The changes are an indication something is going wrong and it needs to be corrected,the set does have a brightness limiter but it only works when the set wants to get brighter than normal,You need the assitance of a servicer to correct this problem.
Oct 04, 2006 | JVC AV-27530 27" TV
JVC AV-27530 27" TV Logo
158 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
