Question about Nintendo DS Lite Console
4G micro SD
I got a 2G micro SD with all files needed ( "_DS_MENU.DAT" , “moonshl” folder , “_DS_MSHL.NDS” file ,"_system_" folder ) to run games and watch movies on Nintendo DS lite using R4.
Now i have a a new 4G micro SD, i tried to copy/paste these files but it didn't work , error message : " Loading .... ' and keeps on for ever .
Thanks in advane
  • 3 Answers
Try R4 Ultra, DSTT card or Acekard they all support capacities over 2GB (up to 32GB)
check http://www.farango.com/farango-catagories/gaming/r4-cards
Posted on Nov 04, 2009
    Novelist:
  • Nintendo Expert
  • 127 Answers
The old R4 Revolution or any non SDHC device only support up to 2GB, wont support 4GB cards as these ones are already SDHC memories.
You need a SDHC compatible flashcart device to be able to use your 4GB or bigger memory.
Posted on Nov 08, 2008
I had the same problem, my 2 gb would work ok but not my 4gb i have heard that the 4gb wont work on the older r4's, so i bought a ds Lite R4 Revolution III (Version 3) from amazon.co.uk and it came with evrything you need and it worked great the address is https://www.amazon.co.uk/s/ref=nb_ss_w_h_/275-1618189-4849908?url=search-alias%3Daps&field-keywords=DS+Lite+R4+Revolution+III+%28Version+3%29&x=14&y=15
My nds says cant find _ds_menu.dat can you help
Hello.
If you're using an R4DS, make sure to read the web address on the front of the box it came in so you can download the proper firmware.
Insert your MicroSD card into it's converter or plug, and slot it on your computer. Browse the card. Your directories (depending on your R4 type) should look like this:
Root:
_system_
moonshl
_DS_MENU.dat
_DS_MENU.ini
_DS_MENU.sys
_DS_MSHL.nds
That is what needs to be on the MicroSD card for it to run.
You must create another folder on the card for your roms.
If this isn't your card, please tell us which card you're using, be it Acekard, CycloDS, or any others.
Oct 07, 2009 | Nintendo DS Console
When i put my r4 into my ds its just says cant find menu?
hi it sounds like a software problem. follow the following instructions. Please can you try and reformat the 2gb micro sd card in your pc and copy firmware from the CD back onto the 2gb micro sd card following the instructions below. be warned that formating will remove even the games from the card so make sure you have a backup of the games saved to your computer. any saved games will also be erased.
To format the 2gb micro sd card
1. Insert sd card into usb stick and into usb port.
2. Close autoplay screen if it appears.
3. Right click on removeable drive. (Eg D, E, F or J etc) that appeared on screen in computer window.
4. Left click on format in menu and when format window appears, tick quick format box and select ok. This will erase all content on the sd card and remove any corrupt firmware.
To reload firmware
1. Insert cd into pc cd/dvd drive.
2. Open cd drive on screen and copy and paste the files and folders from the system/english 1.18 folder on the cd to the removeable drive that the usb and micro sd card are in. The folders that you will copy are "_system_" and "moonshl" and the files will be "menu.dat" and "mshl.nds".
3. Once copied, check removeable drive to ensure files and folders have copied over.
4. Remove usb stick from pc and insert sd card back into R4. R4 menu should appear on DS screen.
this normaly sorts this out. paul
Jul 07, 2009 | Nintendo DS Lite Console
R4 Problem loading error
Get this file extract the file with winrar, and copy the files to the DS card. The file structure should have is:
Files
  • _DS_MENU.DAT
  • _DS_MSHL.NDS
Folders
  • _system_
  • moonshl
You should now put your .nds files onto the root of the card also, and hopefully all should work OK for you
Jun 14, 2009 | Nintendo DS Lite Console
My son got a NDSTT and played games on it for a week, now all it says is MENU? on the top screen of his DS - how do i fix it?
What i would suggest is to take the micro sd card and delete the menu folder and the menutt.dat and anything else associated with the main menu settings. Drag and drop the games folder or games and saves to the desktop and then format the sd card in FAT32.
I appreciate this may seem a little extreme but i have had quite a lot of experience with NDS flash cartridges and the problem you describe usually happens when the menu.tt file becomes corrupt.
Once the sd card is formatted, re install all the nesessary software (you should have these 3 files on the sd card :
TTmenu folder
ttmenu.dat
ttmenu.sys
but, DO NOT put any games onto it until you have placed it into the nds and turned it on allowing the TTcard to build a menu for the games to be loaded from.
Hope this helps
Jun 04, 2009 | Nintendo DS Lite Console
Insalling m3 resl deal but cant find DS MENU .dat
apparently m3 dont do upgrades now but this might help http://www.m3-forums.net/viewtopic.php?f=4&t=312
basically it converts the r4 ds menu.dat to work on m3 simply (may work for m3 real) so now all you have to do is go to r4 download site and download latest version. 1.18 from here http://www.r4dscart.com/r4-software.html (select the english update) then patch ur dat file replace it back to where you took it from before patching and then copy all 4 files ( _system_ moonshi _ds_menu.dat _ds_mshl.nds) into the root of micro sd card. advise you to copy any files/games you have on your mem card then copy the games over to your newly installed firmware. oh by the way in the link i provided on how2 patch the ds_menu.dat it might be bit vague on where you put the ds_menu.dat file to patch it, all you do is drag and drop it into the PATCH app thats inside the "r4 to m3 patcher" folder. post a reply to let me know how you got on
Mar 27, 2009 | Nintendo DS Lite Console
Cannot find menu dat file
To format any drive just insert the memory, right click over your memory drive in My PC window, and there should be an option to Format this drive, formatting will erase all the card contents so make a backup in your computer first.
When you click on "format" a window will appear to chose FAT or FAT32 (try FAT32 first then if not working try FAT), dont have to do nothing on the size option, write a label for the drive if you want, not needed, let Quick Format clear, click on start button and you'll see a proccess bar, when it finish it tell you and you have a formatted drive.
Put the sistem files and one rom to test again in the memory, test it on your DS. Be sure you have the right files for your card, the www.R4ds.cn site only supports R4 cards, not R4 III, R4 SDHC or any fake non R4 hardware.
Dec 17, 2008 | Nintendo DS Lite Console
Ds lite
GO ONTO R4 WEB SITE DOWNLOAD LATEST FIRMWARE PUT ON TO SD CARD,THERE IS SYSTEM,MOONSHL,DS MENU DAT,DS MSHL NDS THEN IT SHOULD BE OK.
Nov 14, 2008 | Nintendo DS Lite Console
I had to format my ds r4 chip memory card and every thing was...
HI REFORMAT THE CARD FAT 32,DOWNLOAD LATEST FIRMWARE ON R4 SITE WHICH IS 1.18 VERSION, THEN PUT ON CARD SYSTEM, MOONSHL,DS MENU DAT,DS MSHL NDS,IT THEN SHOULD BE OK,UNLESS YOU HAVE THE NEW R4 CARD WHICH SUPPORTS SDHC,THEN YOU WANT VERSION 1.19.
Nov 12, 2008 | Nintendo DS Lite Console
Couldn't dind ds-menu.dat using R4 card
hi
first of all , check your r4 version.
there are many.
have you put the right firmware on your r4?
original : http://r4ds.cn/download/r4_v1.18_kernel.html
r4 revolution pro : http://www.r4dspro.com/download_en.html
r4 ultra and de luxe : http://www.r4deluxe.com/en/down.asp
r4 III : http://www.r4dsl.net/download-en.asp
after that it should work.
or maybe you should format your memory card first.
Aug 15, 2008 | Nintendo DS Lite Console
Nintendo ds N5 card stuck on loading screen
found solution to R5:
download latest firmware (1.19 at present) and unzip
format MicroSD to Fat or Fat32
Copy firmware onto MSD in this order ONE BY ONE !!!!!!
This step is very important!!!!
1. DS_MENU.DAT
2. _AXMENU.DAT
3. _DS_MSHL.DNS
4. _SYSTEM_ folder
5. moonshl folder
Then load your .nds files into the root.
I've had absolutely no problems with this card so far and if
installed correctly it works brilliantly!!!
Apr 01, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
452 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
