Question about Bodum Santos 3000 Coffee Maker
Overflow my 2 month old coffee maker has started to overflow out of the top when i make even the smallest amount of coffee. how can i fix this?
Mine just starting boiling over after about the same amount of time, and custumer service says wash the inside where the heater element is? Ill try it but this is getting on my nerves.
Posted on May 22, 2007
Overflow in basket
Steven, I think it`s not the filter or the coffee just that more water is flowing into the basket then it can process. I would try lesser quantity of water first to see if it overflows. Try first with filter only and then with coffee. And before you do all that, your machine should be under warranty and may be returnable to the store. Do that and save the trouble of fixing it.
Mar 22, 2014 | Black & Decker CM1050B
Tip
Keurig B100 coffee maker not brewing
KeuSymptom: keurig B100 coffee maker not brewing. If your brewer sounds like it should be brewing but little or no coffee comes out, the problem may be a simple malfunctioning check valve, located on the right hand side of the unit under the plastic cover. If the check valve is clogged or fails, water from the tank leaks into the air pump (located just below the valve) disabling the pump.
The pump that pushes the water out of the tank located on the right hand side of the unit (I included a photo) has a check valve just above it. On my unit the check valve failed allowing water to enter the top chamber of the pump disabling it. The pump was not damaged it just cannot operate correctly with water in it.
Here is the Fix: Disconnect the check valve and make sure it is operating correctly. Mine was clogged with a small amount of mineral deposits, which was cured by a half hour in a glass of vinegar, and a good rinse. Then disconnect the tubing from the top of the pump and run the unit to allowing the water to escape the pump. Make sure there is no water left in any of the tubing between the pump and the check valve, even the smallest amount will disable the pump again. Reconnect everything and it should work.
Good luck and if you find this helpful remember to thump up vote itc3bb7bf.jpg
on Aug 16, 2010 | Keurig B100 Coffee Maker
We tried the filter to use up our coffee and have had grounds in every cup of coffee since!!! How do I fix it!!
You are probably missing the stopper that goes over the needle. Local ace or true value has them needle is 1/8". Second smallest stopper.
Feb 23, 2013 | Keurig Platinum B70 Coffee Maker
My coffer maker brew basket keeps overflowing. I've deduced that when I push my decanter into the machine, there is so much give that the plastic arm in back pushes it forward and stops the coffee from...
Hello, Srober48 -
Since your Black & Decker coffee maker is only a few months old, it is most likely still covered by warranty.
I suggest you call the Black & Decker Customer Service / Support telephone number printed in your owner's manual / instructions and find out if you can take the coffee maker to an authorized repair center (for free, warranty-covered repair) or if the company will provide you with a replacement coffee maker.
Note: I suggest you do not try to repair the coffee maker yourself while it is still covered by the warranty.
Best wishes.
Feb 04, 2018 | Black & Decker DCM100 12-Cup Coffee Maker
The machine pours too much coffee for an expresso and even for a normal cup. We have been using it for 3 years and this just started a few weeks ago. I reset the machine to factory settings and it still...
You don't mention if you've programmed the quantity since it started behaving strangely, so....
instead of pressing the 'coffee cup ' icon button once, hold it down all the way through the brewing procedure (it will bip) until the correct amount of coffee has been pumped into your cup, then release the button. This quantity has now been programmed into the memory and should produce the same amount of coffee every time, on a sigle press.
Mar 04, 2011 | Saeco Incanto Sirius Fully Automatic...
Keurig platinum only makes 1/2 cup
call customer service 1-866-901-BREW (2739)
Jun 17, 2010 | Keurig Platinum B70 Coffee Maker
My Keurig dispenses about 3oz of water on next to largest setting
I JUST fixed (I Hope!) my 11 month old B60 by taking a paper clip and a straightened safety pin to the top of the coffee maker (where the top pin punctures the top of the cup) and the BOTTOM pin which punctures the bottom of the cup. (remove the bottom dark brown holder by pushing up on it).
After one or two attempts, I ran water through it without the coffee cup, then used a decaf cup and brewed it just fine....
Aug 25, 2009 | Keurig Platinum B70 Coffee Maker
De-scaling
Try doing descaling with a descaling product , like the ones below:
Urnex Cleancaf Coffee Maker Espresso Machine ...
$9.99 - DBROTH
Miele Coffee Machine & Steam Oven Descaling ... $20.55 - Totalvac.com
Apr 19, 2009 | Keurig B60 Coffee Maker
Krups FNC3 Espresso Machine
If it's only 18 months old surely it will still be under some sort of manufacturers guarantee, you don't bin 18 month old coffeemakers nor should you be paying to fix them. Put the problem back in their lap.
Aug 01, 2017 | Krups Novo 3000 /FNC3 Espresso Machine
Limited coffee output
sounds like normal wear and tear, but i do suggest a advanced cleaning of your coffee maker.clean your bean hopper out and sanitize it good, check your owners manaul for tips and tricks on getting the most from your model!
Dec 11, 2007 | Saeco Vienna SuperAutomatica Coffee...
Bodum Santos 3000 Coffee Maker Logo
148 people viewed this question
Top Bodum Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
ray gallant
Kolbrun...
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
