Question about Labtec Curve-460 (50 Pack) Consumer Headphones
Left ear went out
I have these headphones for my mp3 and all of a sudden the left ear went out what do i do
    Problem Solver:
  • 10 Answers
Sorry fellah, sounds like you've pulled the wire loose from one side. Unless your comfortable with pulling it apart and finding the break in the line, you are going to have to sink the money into a new set. Of course you could always try returning the unit with a reciept.
Posted on Nov 05, 2008
I recently bought Ear Pollution over the head headphones and they just stopped working for no reason
It sounds like you have a break in the wires. They make the wires stranded and they are finer than hair but will break if bent back and forth enough or if pulled on hard enough
Nov 21, 2013 | EAR POLLUTION EarPollution CS40...
I purchased this mp3 on 11th devmber. the music is not getting through to the headphones - can you help? is it powered by a battery & is one included as standard?
Hi mharrington9,
You may want to post the make and model of your mp3 player. Someone may have solved the same problem with the same player, and would then be able to give you a more specific answer than this one;
I assume you have replaced or re-charged the battery first, and that full power to your player did not help. If so, it is likely to be a problem with the headphones, the headphone receptacle, or the amplifier inside the mp3 player;
1) Headphone problem?
Get a different set of ear-bud headphones, and try them out. If the alternative set works but your headphones do not work, it's the headphones.
1a) Large headphones, small player?
If your headphones are large, but the power of your MP3 player is small, the player may not have enough power to drive the headphone speakers. If you run your MP3 player through an additional amplifier, you may then have enough power to get sound out of your headphones.
1b) Broken wire in ear bud jack?
Most of my broken ear-bud sets have failed because one or more of the wires has broken, usually at the plug-end. There are 3 thin wires; If you break the left-channel or right-channel wire, only one earbud goes out. If you break the ground wire, both earbuds stop working, or you may hear a very faint sound at full volume. If you like to solder things, it is possible to get a new plug, cut off the old one, and solder in a new one. But it may be easier to get a new set of earbuds.
2) Broken Receptacle?
Plug your ear-buds into a different, working MP3 player. If the ear-buds work, then
Plug your MP3 into a computer through the data cable, and try to play something through the computer.
If the MP3 works through the data cable, something is wrong with the receptacle for your ear-bud plug.
You may be able to get your MP3 player replaced under warranty, since the purchase was recent. Or, if no warranty and you feel adventurous, take the back off and try to re-solder or replace the receptacle-- Though this usually ends in irreparable damage to the MP3 player :-\
3) Broken MP3 player?
If you can't get any music to play through the data cable or the computer, something is seriously wrong with the guts of the MP3 player. Try for a warranty replacement if you can.
Best of luck, mharrington9
Dec 12, 2010 | Audio Players & Recorders
Only the left ear phone works
Try updating the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/156/kw/firmware/r_id/101834
Mar 31, 2010 | SanDisk Sansa e250 MP3 Player
Left side quit working, not earbuds, i tried other sets
I had the same problem. the stereo mini jack connection to the circuit board of the mp3 player is broken or loose. I jiggled the jack around and the sound came back into both ears but that only worked for a little while and is annoying. Basically, unless you can re-solder the mini jack to the circuit board, or get someone to do it for you, your player is now just a flash drive.
Aug 08, 2009 | Mach Speed TRIO Onyx MP3 Player
The sound comes and goes from right part of headset
The left/right problem could be a bad connection on the red/white XBOX cables. Check to see that they're plugged in properly and not loose. You can also try plugging an MP3 player into the red/white jacks to see if the problem is with the headset or the XBOX. If it works ok with your MP3 player, then the headset is working fine.
You can get a new headset controller cable on our web site. Click on Replacement Parts in the left menu for the headset model you own (X1, X3, or X4).
Jul 04, 2009 | Voyetra Turtle Beach Ear Force X3 Wireless...
I cant hear the gameplay in the right ear
Have you tried using your X1 with an iPod or MP3 player? Try that, and if you hear sound through both sides of the headset from the MP3 player, then the problem is in the "Stereo Splitter Cable", which can be replaced. But if you only hear sound out of the left ear from the MP3 player, then the headset is probably broken and you should contact Turtle Beach tech support at support@turtlebeach.com.
Jun 07, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Nov 16, 2008 | JVC Gumy Ear Bud Headphone - Peppermint...
Mp3
Your MP3 file might not have any content on the right channel. Try another Mp3 file. If the problem occurs on another file check the hardware:
Unplug the headphones from the mp3 player. Try another set of headphones. If the problem occurs with another set of headphones, it is a broken player. If using another set of headphones cures the problem, try your original headphones again. Plug your original headphones back in. If the problem comes back, buy a new set of headphones.
Sep 23, 2008 | SanDisk Sansa c140 MP3 Player
Hi, my sansa e250 has sound come out of only one head phone no matter how many headphones i try the same happens
The jack in the e250s is not made of adamantium, so it can actually go bad; however, if you try different headphones and thus determine that either:
  - All the headphones simultaneously went bad in one side
  - Your left ear has issues
  - The Sansa is only cranking out one channel; and
     -the jack feels a little off, or
     -perfectly good mp3s are being played off-balance; AND the balance has not been misconfigured in Settings.
...well then, the plot's moving forward and you can get your ear fixed, or stop the cat from killing your headphones, or re-load Sansa or Rockbox.org firmware, or fix the Settings, or see to the appropriate repair to the jack (depending on your warrantee status and skill with soldering irons and ordering off Jameco.com etc.)
Feb 21, 2008 | SanDisk Sansa e250 MP3 Player
Labtec Curve-460 (50 Pack) Consumer Headphones Logo
123 people viewed this question
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
