Question about Compaq Presario Notebook
Charging problem. my compaq laptop preserio V6000(V6425TU) is creating problem...its battery gets charge till 63%..after dat it stops charging..my compaq laptop is 1 yr old..kindly help...
    President:
  • 1,073 Answers
Since your laptop is one year old, i guess you still have warranty on it. Your battery is bad and you need a new one. Go to the shop and request a new one by the warranty.
Posted on Nov 05, 2008
My laptop emachine 350 is charging but it only show 63% of recharge, my battery is getting full,wat the problem
depending on how old the battery is, it may appear to be fully charging but is in fact only meeting the 63% of charge it indicates.
Firstly, download this and let it confirm the battery charge, it is freeware.
http://www.mioplanet.com/products/batterymeter/
You may find that you need to "educate your battery", to do this, run it down to flat, recharge it and then run it flat again, do this a few times. If the battery then still refuses to charge, you MAY have a defective charger / charging circuit, but more likely, the battery is at the end of its life
Jul 02, 2011 | Computers & Internet
I have a Compaq V6000 laptop. When I try and start it up the fan starts, the disc drive makes a couple of the usal start up noises. About 15 seconds later it just stops and all lights go out. Can Anyone...
With an extensive use of the notebook,
some times notebook would store some static charges which
indeed will stop the notebook from powering up or charging
the battery. The procedure to remove this static charges from
the notebook is known as power drain. Performing a power
drain procedure will not effect any personal data or delete
any pictures from the hard drive on your notebook.
I recommend you use Power Drain procedure by following these
steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Dec 07, 2010 | HP Compaq Presario V6000T PC Notebook
My power supply for my Presario V6000 died due to broken wires. The battery powered the computer until it died. Now, the new adapter will not power the computer.
This is a common eevnt the battery get so flat that the adapter will not charge it quickly.. You need to leave it totally alone for at least 8 - 12 hours... To see if the adapter actually works and PC is good, take OUT the battery, and plug IN the PSU, the PC will work, sans battery just on PSU. If OK, then charge up as related. It will do it after a ling time.. Sometimes batteries go so flat they are ruined, sa a new one may have to be gotten IF it does NOT charge up.
Mar 11, 2010 | HP Compaq Presario V6000T PC Notebook
I have formated ma laptop but not installed sound driver.where can i find sound driver for cozpaq preserio V6000
Sir, first find what is the brand of your sound card. In that way, you can easily find what you are looking for. If you don't know what the type is, you can contact HP to know the type of sound card driver you need. I hope that answered your question.
Jul 14, 2009 | HP Compaq Presario F762NR Notebook
Compaq presario v6000 laptop plugged in but not chargin
YOU NEED TO RECALIBRATE YOUR BATTERY. FIRST UNPLUG THE POWER CORD AND LET YOUR BATTERY RUN ALL THE WAY DOWN TO 5%. THEN PLUG YOUR POWER CORD BACK UP AND LET IT RE-CHARGE THE COMPUTER. SOMETIMES WHEN YOU FREQUENTLY UNPLUG YOUR AC ADAPTER YOUR BATTERY FORGETS HOW MUCH POWER IS ACTUALLY AVAILABLE IN CONJUNCTION TO WHAT THE BATTERY METER IS SHOWING. RECALIBRATING THE BATTERY WILL RE-SET THE METER WITH THE BATTERY.
Apr 06, 2009 | Compaq Presario Notebook
Need sound driver
plz visit hp.com,
good luck.......
Dec 17, 2008 | Compaq Presario Notebook
Battery not charging
take out ur laptop battery safely and again fit it to d laptop......
then see it charges or not.....
if it srill creates problem then put dis baterry in to nother laptop of same version n see how it works...
if havin same problem then it is sure dat ur battery get damaged.....
if it runs smoothly in nother laptop then i think there is problem in ur laptop...
if u hv more problem ask me for more information......
Jun 19, 2008 | HP Pavilion ze4547wm Notebook
Power up
i think urs battery get damaged....
but before replacing it first remove it safely n again fix it on laptop....
then restart ur laptop if same problem is coming...than it is sure dat ur battery get damaged or its efficiency get lower....
send me feed back if ur facin more problems wid ur laptop at shriii2@rediffmail.com
Jun 13, 2008 | Compaq Evo N610C Notebook
Compaq Presario Notebook Logo
82 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
