Question about Toshiba Satellite Pro A200-EZ2204X Notebook
Cmos battery I need to replace the cmos battery on a toshiba satellite a200 but i don't where it is located. any advice would be greatly appreciated
  • Anonymous Mar 12, 2014
    where is the cmos battery located on a toshiba sattelite
  • 2,427 Answers
Hi ,, the battery is located on the main board.(I think you know this) eighter under the keyboard or in the back. You will need to open it up, First take the hinges off by prying it up(the piece that connects the screen to the computer) You will then find the screws that holds the keyboard in place. Take these out as well. Now if you dont see your battery, Turn the laptop over, remove the rom, hd, and rams, (there are a few screws holding them in place then slide them out). now remove all other screws and lift the back cover off there is your mainboard and the battery sould be there.
Here is a Disassembly guide complete with pictures. It describes step by step how to take apart the laptop safely and then follow the instructions backward to reassemble it. This is where i brought my manual from
Click HERE
Posted on Nov 03, 2008
How to remove CMOS battery for A215-S7444? I done a search and got this answer: "This should help: * Remove Laptop Battery * Remove Memory Cover * Spread spring clips to outside and * pull out RAM...
What are you trying to do? Replace the CMOS battery, or reset a BIOS password?
This is what the CMOS battery looks like,
http://www.ebay.com/itm/CMOS-RTC-Battery-Toshiba-Satellite-A210-A215-Series-/270970735656?_trksid=p4340.m263&_trkparms=algo%3DSIC%26its%3DI%252BC%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D15%26pmod%3D160437620636%26ps%3D63%26clkid%3D8748715535548215160
Now view this pictorial disassembly guide,
Page 1 - http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
Page 3 - http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-3.htm
Go to the photo in Step 17, and click on it to enlarge.
See the CMOS battery in the middle/left?
Round silvery looking object. Go straight down from the red arrow to the far left.
That is how to access the CMOS battery.
(Yes I know it states Satellite A200/A205. Same for the A215)
Now BIOS password reset?
Do not know where the two copper pads are to briefly short out. Suspect under the Ram Memory modules, (And under a small sheet of Mylar plastic), or under the Wireless Modem. (And under a small sheet of Mylar plastic)
The links on this solution I gave may help,
http://www.fixya.com/support/t6645137-toshiba_l500_clear_cmos
For additional questions please post in a Comment.
Regards,
joecoolvette
[ Am I concerned that you may have stolen the laptop, or are trying to break into someone else's laptop?
NO
Your real name, and IP address are recorded on FixYa, to give to the authorities, if needed.
I figure a thief would not risk this ]
May 28, 2012 | Toshiba Satellite A215-S7444 Notebook
How to remove CMOS batery from a toshiba a200. A link to a picture if posible. Thanks in advance
Magnify the picture given at Step 17 in the above link (attached below for your convenience) and you will see the CMOS battery around 4O'clock position from the CPU frame. I think the battery is soldered to the motherboard. However, I would like some expert to confirm all this info._1319.jpg
May 10, 2011 | Toshiba Satellite Pro A200-EZ2204X...
Missing Toshiba Satllite m55 Bios Password
To remove the bios password you need to clear the CMOS.
Open your laptop casing look at your motherboard. locate the CMOS jamper it is near the battery. To clear remove the jamper and turn your computer on with in 5 to 10 seconds and turn it off. Reinsert the jamper back to there proper place and try to turn go to BIOS if there will be a password box appear.
You need to open your laptop and look at the motherboard and locate the CMOS battery. Just remove it with in 5 minutes to clear BIOS password.
Apr 12, 2010 | Toshiba Satellite M55-S135 Notebook
Toshiba Satellite A200 start up passwod
yes there is, you will need to get someone who can put the laptop apart for you, if you don't know how. they will need to remove the cmos batt and leave it out over night and then put it all back together the next day. that will flash your cmos back to factory settings. other then that you will need to replace the bios chip on the mainboard and that can be very hard to do
Sep 12, 2009 | Computers & Internet
Toshiba A200
The common mistake made when repairing toshiba laptops is forgeting to remove the battery. If you forget this it can cause the problem you are describing. And this has happened to me before (it was not my laptop and I was lucky to figure a possible solution to the problem. Remove the battery and disconnect the power supply (if you are up to finding and removing the cmos battery it might take less time) then leave it a few day with out power this sould reset the bios and restore setting and hopefull solve your problem.
Nov 06, 2008 | Toshiba Satellite A205-S4617 Notebook
CMOS or RTC battery for this laptop : can it be replaced
Hi AshishB, Yes, Toshiba does refer to the CMOS battery in their literature as the real time clock battery. Your retailer is half right, the battery is on the motherboard but its attached via a connector and it can be replaced. Here are links to a couple of venders that sell the RTC battery for your laptop: - Http://www.sparepartswarehouse.com/Toshiba,Satellite,L15-S104,Laptop,Batteries-Backup-RTC.aspx - http://cgi.ebay.com/Toshiba-Laptop-motherboard-battery-cmos-L15-S104_W0QQitemZ170060189842QQihZ007QQcategoryZ3666QQrdZ1QQssPageNameZWD1VQQcmdZViewItem Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 18, 2007 | Toshiba Satellite L15-S104 Notebook
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
501 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
