Question about Zanussi TC7114W Electric Dryer
My tumble drier no longer condenses! Water comes out the middle of the machine.
The water no longer collects in the removable reservoir when I use my drier. It spills out onto the floor via the middle of the drier. I have checked the seal at the back, checked the 'o' ring and valve, and thoroughly cleaned the venting tray - however it all looks fine. What else could it be?
Hi LesleyB, I have just read your question on Fixya .com and I have the same problem with my dryer. I know your question was raised some time ago with no answer on Fixya...but I was wondering if you ever got to the bottom of the problem? Like I say I have the same model here in the UK and cannot find anyone who knows what the problem is (without charging me the earth to come look!) Hope you can help...Thanks Simon B, Manchester...UK
Posted on Apr 16, 2007
SOURCE:
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
Why does my tumble drier not get warm?
you could be looking at several problems
1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough!
2 it could be the water collection pump? Can you her it running?
3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Jul 20, 2010 | Zanussi ZWF1420W Front Load Washer
I have a Hotpint Aquarius CTD00 Condenser Tumble Dryer, it has stopped drying the clothes. It occassionally works on the high setting (but makes my clothes smell a bit burned out and shrinking) but it...
it could be blocked up with lint, take out the condenser (silver fin bit) and clean run under a tap if necessary, this is the most important bit of the condenser if this is dirty it reduces the efficiency of the dryer. clean all filters with a vacuum cleaner even remove them and clean where they sit in the machine with the vacuum cleaner.
for the reservoir remove a check the inlet is clean and clear. look inside the machine where this is located and again clean and clear this area, then using something long and thin press open the valve that the reservoir mates with (this can often stick with lint and water residue) be-careful though when opened the valve will **** out water so have a few towels to catch it all. and finally raise the front feet a little this will help the water fall to the reservoir.
if this does not work the internal tank may have fluff and this would be a big job to get to this and clean it you have to strip the drum out which can be a pain.
Jul 22, 2009 | Hotpoint Dryers
Hoover Vision HD VHC391 saying it is full of water
My son seems to have fixed my dryer.
Although I followed the instructions about cleaning the filter after each cycle and the condenser after ten, fluff had blocked the drainage from the internal reservoir to the water collection bottle. It seems like this will be an ongoing problem, as even cleaning every time, fluff will gradually biuld up. The filter isn't good enough to stop fibres getting into the condenser and then into the reservoir behind it.
I expect that taking the cover off the reservoir to clean it invallidates a guarantee if you have one, but that is what my son did and now the dryer is working.
Jan 12, 2009 | Hoover HDV7FM Electric Dryer
Asko T741 - Thermostat keeps cutting out
Ken from Mecheltec suggests removing condensate sump and pump assembly and servicing it. Clear condensate hoses from lint and debris then carefully reinstall assembly. You should be ok.
Oct 06, 2008 | Asko T741 Dryers
HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Jul 09, 2008 | Dryers
Bosch condenser tumble drier.
Maybe the pump is bad. With the power off, remove the power wires from the pump terminals. Then connect the power wires to an electrical tester light or meter. Then turn on power and run the machine in a dry cycle. If you get power, then you know that power is getting to the pump abd the pump is bad.
Feb 11, 2008 | Dryers
Leaking condenser tumble dryer
i have the same problem i need help sick of putting towels down infront of it
Dec 28, 2007 | Washing Machines
Zanussi TC7114W Electric Dryer Logo
194 people viewed this question
Top Zanussi Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
