Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Washer dryer hi i have a bosch wft 2800 and the dryer wont heat up or dry anything i have checked the suds pump but thats all clear hope you can advise many thanks C Twilley
  • 2 more comments
  • galata1 May 11, 2010
    Where di I find the thermostat to get to the reset button?
  • Anonymous Mar 22, 2014
    smell is coming from the machine
    during the number 1 drying run, the machine produces a bad smell. what can I do to stop this smell
    there is a bad smell coming from the machine, how can I stop this smell please
There is a switch on the thermostat that may just need resetting. If I remember it is a push switch. This will reset the thermostat and the heating element should start working again.
Posted on Mar 30, 2007
  • 944 Answers
Here is the link for a manual for your washer/dryer if you need it; https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM sounds like the heating element has failed, or just possibly the thermostat for the hot air. follow this link for a list of spares if you want to try it yourself, or for bosch repair centre details if not. http://www.bshappliancecare.com/Bosch/boschspares.html ask if you want to do it yourself for any guidance you need. Hope this helps :)
Posted on Mar 21, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 21, 2007
    first link was bad - here is the right one;
    click "instruction manual download"
    type WFT in the search box, and you are taken to the downloads page - sorry i couldn't link to it directly.
    Hope this helps :)
Pls how can i unblock a pump on bosch logixx
Turn it anticlockwise
if it won't turn it has something inside jamming it
you will need to remove the pump and filter assembly and take it apart to clear it
Jan 08, 2015 | Bosch Logixx WFT 2806 Front Load...
How do I clear code E27 from my Bosch washing machine?
I had to call a certified bosch repair center. They sent someone out who entered some sort of code to put the washer into diagnostic mode. Once it was there, the code cleared and my washer worked again.
I asked for the code, and the repairman wouldn't give it to me.
Aug 31, 2010 | Bosch Logixx WFT 2806 Front Load...
Washing machine not washinf/spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Bosch Logixx WFT 2806 Front Load...
I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Nov 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Not heating up
some times the heating coil breaks or the thermal resistor goes bad
Nov 02, 2009 | Bosch Logixx WFT 2806 Front Load...
No heat during drying cycle
your heating element or the thermostats that control the heating element could be bad. research no heat for your make of dryer, it should show how to ohm the thermostats and element for fault. They should all read 000 when ohmed. 000 being a complete circuit. I have been having thermal fuse problems with my whirlpool dryer, so I'm learning as I go.
Oct 22, 2009 | Bosch Logixx WFT 2806 Front Load...
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx vented dryer not working correctly
I had the same problem.
I took of the cover on the back and found the heating element had blown. I just replaced it for a fraction of the cost of a new drier, just unscrewed it and conected the two wires easily.
Jan 25, 2009 | Bosch Logixx WFT 2806 Front Load...
Machine is locked
to open your door make sure all the water is out of your drum if not get the outlet hose and place on the floor into a bucket if water comes out than your pump is either blocked/faulty
Aug 12, 2007 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
996 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
