Question about Panasonic (ETLAE900) Projector Lamp for PT-AE900U
Panasonic PT-AE900u no image
Hi:
I have a panasonic PT-AE900U projector whose bulb works fine but no image appears on the screen even with a source conencted -- I can't even get the menu to appear. It looks like it's in "shutter" mode and may be stuck there for some reason. I've called Panasonic Tech Support and they suggested I try resetting it -- which I did. Nothing. Before I send it in for repairs, any ideas of what it might be?
  • benvpr Nov 03, 2008
    Your suggestion of unplugging the projector and waiting 4 hours, as well as removing the batteries from the remote unfortunately did not work. Anything else I can try?
    Brigadier General:
  • 3,614 Answers
Unplug the unit for at least 4 hours. remove the remote battery also..
lt me know.
keeps us updated.
Posted on Nov 03, 2008
My screen is yellow with grainy lines. I replaced the bulb (after only 776 hours), but the problem persists even with the new bulb. Is there another part inside that may need replacing instead?
The organic polarizers can get burnt by the bright light after a long time. The blue one is most susceptible and results in a yellowing of the projected image.
You can see if it's damaged when the optics unit is dismantled.
Jul 28, 2011 | Panasonic PT-AE900U Multimedia Projector
Our projector (Panasonic PT AE900U) is still working but the picture seems very dark all of a sudden. we are wondering if this means we need to replace the bulb and if so, what do we replace it with.
You need a new lamp. Cost is around $350. The following site shows replacement:
http://www.shopvsc.com/Replacement-Lamps-for-Panasonic-Projectors-s/284.htm?searching=Y&sort=7&cat=284&show=50&page=1&f-PT-AE900=109462
Oct 16, 2010 | Panasonic (ETLAE900) Projector Lamp for...
I have a Panasonic pt-ae900u projector that doesn't project an image. The lamp fires up but no light makes it past the LCD panels, no video or menu graphics, nothing...help would be appreciated
I have the exact same issue with my projector and was wondering if anybody has an idea what the problem/solution could be? Have checked all internal connections, wiring, etc. but nothing is physically wrong with it. Powers on and off with no issues; bulb is working but no light out of the lens. Please help!
Oct 14, 2010 | Panasonic PT-AE900U Multimedia Projector
Lines on the screen regardless of the input source. I replaced the bulb and still have the same problem...
One of the 3 lcd's has bad bad pixel drivers...lines could be
horiz or vert...need to reolace the lcd..
Art
Jul 04, 2010 | Panasonic PT-AE900U Multimedia Projector
Red horizontal lines across the screen i have a pt-ae900u
Check out this solution for the same problem:
http://www.fixya.com/support/t305560-even_spaced_vertical_lines_across_whole
I was successful with this hint.
Jul 08, 2009 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U Projector Lamp stops working (intermittent)
since it has worked 1200 hours or even more since u have been resetting the counter! just change the lamp, resetting the counter does not make the lamp work or not work , it is only a reminder for the user to change the bulb when it should be & that u have some balance hours left to procure a new lamp!
if the brightness is adequate, then it is a ballast problem & not lamp problem!
buy a new lamp as u will anyway need to , fit it & it may solve ur problems permanently!
Jan 27, 2009 | Panasonic PT-AE900U Multimedia Projector
may i know now what is the age of your projector. have you done replacing the lamp of the unit before.
Lamp life varies by manufacturer and projector type. Lamp life also depends on the projector's environment: air flow, clean air, and also on the level of usage. Check the user's manual or specification pages for your projector to determine the exact lamp life.
Nov 04, 2008 | Panasonic PT-AE900U Multimedia Projector
Bulb not coming on?
Hi - You can download the manual by clicking the link underlined in blue below:
PT-AE900U
Most likely the air filter needs cleaning. See page 55
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 13, 2008 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U
Very confusing posting !
RGB input for DVD Player ?
HDMI input missing ?
Apr 13, 2008 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Oct 25, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic (ETLAE900) Projector Lamp for PT-AE900U Logo
130 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
