Question about Braun Syncro 7505 Electric Shaver
Blue Automatic Lock Button is broken
Repair should cost me 25? (>30$) on material plus about 30? (>40$) for the technician. Does anybody have a better solution? Can anybody explain how to open the casing (I can get a used model for less than 50?)?
  • Anonymous Nov 09, 2007
    Mine's an 8000 model which has suddenly become very noisy. I suspect a loose component inside but I can't figure out how to get it open!
  • Tek4bama Jan 24, 2009
    I have a braun 7526 and the blue button will not let me turn off the razor. How and who do you send it to to get htis fixed.
    Tek4bama
Update to solution #4 (posted 9/17/07). The fix I presented previously is partly wrong. The update: pry off the side panels by removing the rectangular plastic panel at the power cord insertion end. Then look for the clips (internal) that are holding the side panels. Use a screw driver to bet them to release. Then the side panels will come off and you can make the repair. (There is a graphic of this process in the Braun 8585 User manual.) Cheers.
Posted on Sep 17, 2007
Here's the fix. Braun sells a replacement part (it's the whole shell of the shaver, excluding the side panels. Remove the shaver head, then pry off the side panels (use a very thin screwdriver like tool). Start prying carefully at the head end and work toward the tail (cord end). The internal clips are the strongest at the tail end. Once the side panels are removed, you'll see four screws. Remove them and the motor and battery elements (they're modular) can be removed. Place these ineternal elements in the new replacement shell (case) and rebuild in reverse order. That's it!
I had the same problem and got as far as you tryin to open it. Like you, I removed a few parts at the head and came to a dead end. I then removed the side grips and there is no solution under there either. It is frustrating because it seems like a small problem like this should be easily remedied. It's an insult to the consumer to make them purchase a whole new shaver for the failure of a five cent washer.
Posted on Jan 31, 2007
This AM, my Blue Automatic Lock Button on my 7526 got stuck in the "ON" position. I had to leave it turned-on until the battery ran dry. Did you ever figure out how to open the case for inspection or repair? I'm stuck -- I have tried going thru the top but got stuck after removing the 1st few parts. Besides that, I can figure is that the side grips may need to be pried-off to reveal some screws which would allow the entire guts to slide out the top. Any and all informed suggestions appreciated....
Posted on Nov 17, 2006
    Problem Solver:
  • 10 Answers
Parts are not available at this time ,accessories are even dropping off
Posted on Sep 29, 2006
2000 Firebird - Gear shift button broken- can't shift - A/T
You could remove the handle and pull on the plastic rod, or disassemble the console to access the shift lock.
You may need a shop manual for repair info.
Jan 22, 2014 | Cars & Trucks
White screem
top or bottom? either case your screen connection is broken or lose. ebay a replacement screen and google instruction on repairing it.
or
email me: pepito01226@gmail.com i charge $50 for labor and shipping cost, plus cost of material it takes me 2 to 3 weeks to repair your NDSI (this will include shipping time)
Mar 13, 2011 | Nintendo DSi Matte Blue Console
The little dial (record, stop, play) fell off along with the blue button. Can it be repaired and how much is the cost
To replace the broken component, the camcorder will need to be disassembled. This can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Feb 08, 2011 | JVC GR-D370 Mini DV Digital Camcorder
Printer is wanting to print in blue not black!?!
It would seem to me, that what you are describing is a cartridge phase problem, which will happen if the drive assembly is not correctly reinstalled after replacing the broken locks...
The technician who replaced the cartridge locks will have to remove the drive assembly and re-install it correctly.
Apr 29, 2010 | HP LaserJet 3600n Printer
Where can I purchase a power supply for my Dell 1800MP projector? When I plug it in, I get no light on the power button (not blue or amber), so I assume it's the power supply.
I will repair these projectors for you at a cost of $40 plus actual shipping from me to you. You would pay the shipping cost to me. Considering the effort it takes to repair one of these units, this is a fair price. I have repaired numerous of these units with 100% success. My occupation is working as a power supply designer for one of the largest manufacturers of drivers for LED lighting. mooredesigns4u@att.net
Dec 23, 2009 | Dell 1800MP Projector
My screen crack plus the ink spill
have it replaced then, there is no way to repair the broken screen itself...it's fairly expensive though, it will cost you about 40-50-60% the cost of a new PSP(that would be an OK price)...
Feb 19, 2009 | Sony PlayStation Portable (PSP) Console
Battery contact is broken
you can have it repaired but the costs of a good box (not too small and not to big, special foam, are probably high and the repair cost are the worst of the technician fee (material is porbably within a few dollar ) but your gues is as good as mine , go to a olympus dealer , ask him what he /she thinks the cost of repair would be and weigh that against the price of a new one.
May 26, 2008 | Olympus Camedia D-395 Digital Camera
Nintendo DS hinge broken/cracked
Hi Worried mom, www.playstationclinic.com can fix it. Repair for your problem is $40 plus shipping costs. You will get a brand new case, hinges Cleaning and tune up.
Sep 20, 2007 | Nintendo DS Console
Braun Syncro 7505 Electric Shaver Logo
786 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Joseph Hoffmann
Craig
Level 1 Expert
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
