Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
Computer will not boot up.
I just put in a new Asus M3N72-D mother board. A new AMD Athlon 64 x2 5600 processor. New Crucial Ballistics DDR2-800 (4-Gig), and a new 450W power supply.
Put it all back together this weekend and when I power on all I get is fans running (all case fans and CPU fan) the green light for the hard drive flashes a few times. The green lights for the CD/DVD roms flash a few times (but the roms will not open when I push the open/close button). I get nothing on the monitor and now sound (no beeps or beep errors or anything). The fans run for 20 seconds or so and then it power off for about 2-3 seconds and then automatically power up again and does the same thing fans run, lights flash, roms will still not open (when I push the open/close). No video and no beep codes or anything. It will continue to do this over and over again and the only way it will stop is when I turn off the power supply switch.
I have tried clearing the BIOS, even tried my old processor (AMD Athlon 64 X2 3800), tried one stick of ram all the usual stuff. It always does the same thing.
Note under product I had to list a different board the M3N72-D that I have was not an option.
I am leaning towards "a bad mother board". Any body agree or have another opinion?
  • 1 more comment
  • stltrevman Nov 03, 2008
    frcs68 and Butch1964, thank you both for your comments.
    frcs68 I have tried everything I can think of with the memory sticks. Switching memory sticks, trying with only one stick, no memory at all, and even tried one of my old 512 sticks that works in another rig. No matter what I have tried I still get the same results described in my original post (No BIOS, no video, no beep errors) just fans running and blinking lights. I tried booting with the CPU fan unplugged and feeling to see if the CPU heat sink would start to warm up and nothing so I don't thing the processor is even firing. Wondering if it might be the processor I put my old 3800 in and the same thing it does not warm up at all. It sounds like you may also think it is the board so maybe this re-enforces that opinion. From what I hear it is not real uncommon to get a bad board "out of the box". I have just never had one yet. By removing all "external devices" are you referring also to the hard drive? This is something I have not tried. I believe even without a hard drive / operating system it should still boot up to BIOS correct? In other words the minimum components needed to bring up BIOS would be the motherboard, CPU, Video card and PSU (of course). Is this correct? If the problem was the memory would you typically get a beep error? Especially with the memory completely out if the motherboard were functioning properly I should get a beep error correct? If the problem were the video card I would get a beep error (one long, two short...I experienced this one before.lol). What if it was the processor? Would I get a beep error?.
    Butch1964 I had a Hiper 580W power supply in this rig originally thinking it could be the problem I put the new 450W PSU in it. I know the 450 is not ideal but it was what I had to try in it. When I take a look at the PSU calculator on the ASUS site with the board and everything I have hooked to it (including the GeForce 7600 video card) it calculates a minimum of 350W. Not saying I would rely on a 350 or even a 450 to run it all the time but I would hope it would at least boot it up. I am curious what is the best way to check the PSU? You mentioned a PSU checker that you got from Tiger. I will check into that. Does it read all of the pin voltages? Does it check it under a simulated load or anything like that?
    Thanks again for the comments and anything else that anyone has to offer on the additional info.
  • stltrevman Nov 04, 2008
    frcs68,
    I tried to get the board to run outside the box as you suggested. I sat it on the static guard bag that it comes in and had nothing connected to it except the processor (tried it with both the new 5600 and the old 3800) and the power supply hooked up. I also tried it with ram and with out ram. Still nothing. Looks like it is the board. I will have to RMA it to NewEgg.
    Butch1964,
    I got a look at the power supply tester in action. Since I am a "cover all my bases kind of guy" lol, I took both power supplies to a local computer store and they were kind enough to test them for me. Both checked out good. So when I get my new board I can put my 580W back in my rig. I'll keep the 450W and build a rig for the kids.
    Thanks much to you both for taking the time help. This is only my third build and the first two times I just put everything together and turned it on and all was good. I have never had to do much trouble shooting before this one. I have certainly learned a lot and a couple of things to try in the future. I hope to do one more post on this one...That will be to say all is good after replacing the board.
    Thanks,
    Trevor
    St. Louis, MO
  • stltrevman Nov 05, 2008
    I big thanks to frc68 and Butch1964 for your time and input.
    I got the new motherboard in and everything works great.
    I am going to do another build soon (for the kids). I hope that one will go as smooth as the first two I did (got lucky...no troubleshooting involved), but if not I learned some valuable info on this one and will be ready to do some trouble shooting next time.
    Thanks again guys and happing computting : ).
    Trevor
    St. Louis, MO
    Genius:
  • 1,605 Answers
Remove all external devices. except the memories.
turn on the PC.
it if comes on insert each of the external device one at a time, till you come across the one that is causing the problem.
if it doesn't come on, remove the memories. and swap the memories. if it still doesn't come on, remove the memories. and see if the BIOS come sup. if it doesn't, then you have motherboard problem.
go back and check all connections. make sure the connectors are in right orientation and not pins are missing.
Posted on Nov 03, 2008
  • Frank
    Frank Nov 03, 2008
    The best thing I can offer at this time is to get the diagram or pin call out for the mother board power input, and the pin out put from the power supply, match them up.
    the other suggestion is, you can run the mother board w/o any devices.
    I had run the motherboard outside of the box, when I can't get anything to come up. The reason for that is, I do find (not always) the ground for the board some time Short out the board, or the board is so close to the case, it creates a magnetic short (around the power input).
    the answer to you question is no. the machine will give a beep or 2, if it motherboard is running. if the motherboard is not up, you wouldn't get anything.
    try this, let me know if you get anything with the motherboard outside of the box.(I mean completely).
    not haunging out.
    Scholar:
  • 147 Answers
I have built several gamming computers, one with Asus and had good luck. What I do have is a power supply checker that I got from Tiger Direct that I use alot. To me a 450 watt PS sounds a little small . Sounds like it cant regulate the voltage, expecially the 5 volts. I have a master power supply (650 watts) that will hook up to any board or hard drive. I try it when I have this kind of problem. The only thing I dont like about Asus is that they have so many pins, so I would double check the pin settings.
Did the power supply come with the case.. If it did, change it. I have never had any luck with those. I really think they use 2nd hand ones for kits. Just my opinion GOOD LUCK
  • butch welch Nov 03, 2008
    It does read all the voltages and it not under load. Im sure it would have an internal load. Im starting to think like you, being the board. Keep me informed.. Jfw46@hotmail.com
  • butch welch Nov 05, 2008
    Congrats, Boy I know thats a good feeling. Lets keep in touch to swap ideas or problems. Looks like you have one hell of a system..Ill give you a ataboy......
Sir , i found my mother board is good . but , my processor failed to boot mine is AMD ANTHLON 64 3500+ . I dont have even a small damage to the pins in the processor , everything is good. my processor...
Processors do not fail unless they are mishandled or installed incorrectly. This system is very old and uses memory that is no longer available. Try starting your system with no memory, does it start to beep repeatedly? The memory may be at fault. No beep, could be the motherboard has failed.
You will not find replacement parts, you will need a new system.
Feb 13, 2011 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
Can I use P4 478 processor in K8V-MX mother board
You can not use intel ,It is a athlon platform Mother board.
Follow the link, and you can know every thing from here.Just click here.
Hope it will help you.
Regard's
Shibuda.
Dec 31, 2010 | ASUS K8V-MX Motherboard
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
Will a amd athlon 3000+ fit in a asus km400
you need to find out what socket the amd athlon 3000 is and what the socket for the asus is go to amd's site and then the asus site they can help big time..=)
Nov 01, 2009 | Computers & Internet
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Driver
Thats a prosessor, theres just one driver for that, and still its not a must have.
now if its a motherboard that you need drivers for, now just the processor, go over here and select the right motherboard, you will get the drivers you need.
http://support.asus.com/download/download.aspx
and you can get a prosessor driver from here for AMD
http://support.amd.com/us/Pages/drivers.aspx
Let me know how that goes.
Thanks,
Ekse
Jun 03, 2009 | AMD Athlon 64 X2 4000+, 2.0 GHz...
Problem at boot
There is a mechanical switch connector available to determine if someone has opened the chassis.
You can bypass this through the BIOS by entering the BIOS on bootup (DEL? message at bootup? F1?) then look for the system chassis intruder alarm and DISABLE
Another option is to find the pins that the switch is supposed to be connected to (documentation on the ASUS P4B motherboard) and jumper them.
Jul 03, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
660 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
