Question about ASUS P4P800 SE (890552603657) Motherboard
What is a chassis intruder?
Every time i try to start the computer, it boots normally , but quickly stop the startup with a message :FATAL ERROR . CHASSIS INTRUDER . and i cannot go further not even in the bios setup . What does this message means ?
    Problem Solver:
  • 17 Answers
That message means that the side panels of the case of the computer are not closed. You need to replace the side panels if you removed them. And, if you did not, you have a bad intrusion switch. The switch tells the computer that the side panels are open or removed completely. Make sure you screw them back in completely as well.
Posted on Nov 06, 2008
Chassis intruder,fatal error system halt on asus p5pe-vm.how can i fix it
Hello, you can download a manual here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Please select your windows version.
Select manual and click on global for download.
Unzip the file before installation.
And remove the cable on the mainboard for the contact on the chassis.
When that is done enter the bios and set the setting for the chassis intruder to off
Read about that in the manual.
The chassis intruder is used by admins to see if the case have been opened
when the case is opened the bios will block the system from booting until the setting in the bios
is set back to normal.
Oct 06, 2011 | ASUS P5PE-VM Motherboard
How to fixed chassis intruded fatal error system halted
Good day! here's the following steps hope it will help you.
Unplug the computer
Take the MOBO battery out
Remove the chassis jumper
Wait a few minutes
Replace the chassis jumper
Replace the MOBO battery
Plug the computer in
Jul 24, 2010 | ASUS P5V800-MX Motherboard
Chassis intruded
try reassembling your CPU as if it is new. make sure all sockets are securely attached.
Dec 30, 2009 | ASUS A8N32-SLI Deluxe Motherboard
Chassi Intruded" then "Fatal Error...System Halted" asus pvc5mx
okae...
first should you do is.. buy a new motherboard.. because like my motherboard, there is no solutions for that error nd problem...tnx
Dec 17, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis intruded ? fatal error... system halted in asus p5sd2-vm mother board
first you have to check the RAM,, then mother board or processor,, ,,, make sure the pc while booting memory check is going with out problem..s
Sep 29, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
ASUS p4 intel motherboard giving chassis intruded. fatal error message and system would not boot unless reset again. can anybody solve this?
Hi there.
Start the PC and enter the bios using either the Esc or Del key, once in the bios set the chassis intrusion to "disabled" save the changes and exit the bios, the computer will now restart and you should be able to boot into the operating system no problem.
Good luck and thanks for using FixYa!!
May 01, 2009 | ASUS P4GE-MX Motherboard
Chassis Intruded
clear your bios, close very good your case, open bios disable chasisis open detected fro yes to no, (or in some model from enable to disable ) change saves exit booting and good work.
Apr 07, 2009 | ASUS A8R32-MVP Deluxe (A8R32MVPDLX)...
Chassis Intruded, Fatal Error...System Halted
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
Mar 20, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis intruded
Try disabling this feature in the BIOS. Here is a link to the manual.
Best of Luck,
Spare head 2
Jan 04, 2008 | ASUS P5S800-VM Motherboard
ASUS P4P800 SE (890552603657) Motherboard Logo
696 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
