Question about Hoover Vacuums
My henry hoover has just stoped working its not the fuse do you have any ideas
I had exactly the same problem.there were no burning smells coming from it so nothing seemd obvious.I then took it apart and checked that all wires were connected,which they were.Then decided to check the plug.After replacing the fuse I chopped the cable of (as it is a seald plug) and connected up a new one.Hey Presto,Henry was alive again.Hope this helps.
Posted on May 08, 2009
Same here. Took mine apart and found the electrical contacts which carry power from the outside to the reel (which spins when you pull out the cable), had broken.
You can buy new ones on ebay for £5
However the tracks which they touch are a bit burnt on mine so this will need cleaning up too.
I'll know more about this when I fit them.
Graham
Posted on Nov 15, 2008
Electro conductive grease for henry hoover
if you are in the uk try
01484 718674
or try some KY Jelly or even vaseline as it contains a lot of water
Oct 14, 2013 | Henry Vacuums
Hi, I've got an Henry Hoover. I've got electric
TRY RUBBER GLOVE / IT WILL STOP ELECTRIC SHOCKS ,I AM A CLEANER AND IT WORKS FOR ME
Apr 09, 2013 | Vacuums
Henry hoover brush not rotating so not picking up
Check the ends of the rollers for a build up of hair/thread, etc between the bar and the ends. remove if found.
Dec 29, 2012 | Numatic Henry Bagged Canister Vacuum
Henry hoover
Hi it can be the connector at the end of the Henry cable inside the cable rewind unit happened to us!
Nov 14, 2012 | Numatic Henry Bagged Canister Vacuum
My hoover smells of ammonia
I too have a problem with a bad smell coming from my henry hound hoover, but thats probely because i haven't used a hoover bag. I took the cloth filter out,banged all the dust off, then sprayed it with 'RugDoctor' pet stain remover for carpets and upholstery. It still smells a bit, but not half as bad as befor. I have now ordered a reusable,zipable,washable cloth hoover bag especially made for Henry's. It cost £8.80 from ebay with free postage. Hope this helps Nikki.
Oct 30, 2009 | Numatic HHR-200 Henry Hound Bagged...
Henry hoover cuts out
A 5amp fuse will struggle on start up on anything over 1000watts. Check the rating plate on the appliance for total load
Aug 19, 2009 | Numatic Henry Bagged Canister Vacuum
Rewiring a Henry Hoover
Ignoring for the moment the fascinating question of why you would actually want to do this...  I'm sorry to tell you it won't work. Swapping the wires over will make no difference.
Apr 20, 2009 | Numatic Henry Bagged Canister Vacuum
Hetty hoover not working. It was working ok until I opened it up to search the bag for a missing jigsaw piece and I put it all back and I hoovered the mess on the floor, then switched off and switched on...
Know cut off switch, its just not getting power ? 2 things its ether at the wall plug or in side the unit. I have never found a fuse in side them , so it may be just a lose wire did you try other plugs in the house . good luck DFD
Jan 22, 2009 | Henry Numatic "" Canister Vacuum
Vacuums Logo
1,138 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
