Question about Symbol LS2208 Handheld
Problem read code EAN 8 AND UPC 12 and symbol LS2208
I have this situations: my system don't read any code begining with 0, please need this configuration for symbol LS2208.
Thank you.
2 Suggested Answers
SOURCE: i have this situations: my
Your scanner must have been delivered with a "Quick Start Guide".
All you need to do is to scan the following barcodes from thar Guide:
1.Set Defaults
2. Scan Options
3.<Data><Suffix>
4.Enter
5.The barecode for whatever type of connection you use (RS232, Keyboard, etc.)
Posted on Feb 04, 2009
  • 34 Answers
SOURCE: cannot find a way to
http://www.fixya.com/support/t1857832-need_convert_upc_barcode_number_ean_13
have a look there. it will explain.
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Posted on Oct 19, 2010
Im trying to get my ls2208 scanner to read comic book barcodes its 13 plus the 5 digit extension can i get some help with this. im running windows vista 64bit not sure if that matters or not.
Just take a Print out this PDF file and Scan the Barcode
1st u need to scan the enable Interface Barcode then Scan Any barcode Length
Cheers
Hope its solves
Sep 05, 2011 | Symbol LS2208 Handheld
Cannot find a way to configure ls2208 to perform expansion of upc-a to ean-13 barcode. I need this characteristic enabled in order to transmit a complete ean-13 barcode when it starts with a "0",...
Oct 01, 2010 | Symbol LS2208 Handheld
Can i make my ls2208 read ean 13+5?
Hello, here is the link for the ls2208 product reference guide, in this it will walk you through the symbologies and how to scan them
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=165172946&stateId=0%200%2019405968
if you need additional information please let me know
Kim Ganoe 800.933.2839
Mar 22, 2010 | Symbol Hotshot LS2106 Handheld
I would like to transmit EAN-13 bar code without check digit, but closed by ENTER.
If you would like the LS2208 to transmit only the first twelve digits of an EAN-13 barcode followed by an enter you will have to write an Advanced Data Formatting rule using barcodes from the LS2208 Product Reference Guide found here: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=114420371&stateId=1%200%20114410810
The barcodes you will print and scan in the order they are listed are:
Begin New Rule
EAN-13 (from the Critera pages of the ADF section)
Send Next 12 Characters
Send Enter key
Save Rule
If all other barcodes require an enter key make sure you scan Scan Options, Data Suffix, Enter (from the same manual or from the Quick Start Guide) before scanning the ADF rule above.
Jul 13, 2009 | Symbol LS2208 Handheld
UPC TO ISBN CONVERSION
Scan the Enable Bookland EAN barcode from the LS2208 Product Reference Guide. It is on Adobe page 166 of 342 of this guide: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=113980484&stateId=1%200%20113974371
Jul 08, 2009 | Symbol LS2208 Handheld
We need to convert UPC-A barcode number to EAN-13
Most scanners will convert UPCA to EAN13 as you scan if you have that setting checked. A 0 will be added in front of the UPCA to make it an EAN13. Nothing else changes. You can read about this stuff on Wikipedia.
Mar 24, 2009 | Symbol LS2208 Handheld
I have this situations: my system don't read any code begining with 0, please need this configuration for symbol LS2208. Thank you.
1.Set Defaults
2. Scan Options
3.<Data><Suffix>
4.Enter
Jan 30, 2009 | Symbol LS2208 Handheld
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
Symbol LS2208 Handheld Logo
108 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
pkwc
volk1
Level 1 Expert
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
