Question about Canon PowerShot S2 IS Digital Camera
I have recently bought this camera. I must have pressed some button as after I turn it on I don't have an image on the LCD screen nor see anything in the view finder
My S2IS also has the black screen problem. The trick of setting 15 second shutter time and opening the batetry case while the shutter is open no longer returns the camera to health. I have little faith in Canon reliability - this is not the only Canon camera to fail me. Perhaps I will try to get it repaired, perhaps I'll just buy some other, ANY other brand. Nuts.
Posted on Sep 06, 2009
I have the same problem with S2...image and viewfinder and LCD are black.... Canon should replace anybody having problems with censor...we have paid for it....DO NOT BUY CANON IN FUTURE IF THEY FAIL TO FIX THIS PROBLEM
Posted on Jun 21, 2007
Don't pay a cent for that to be fixed! It is a known problem with the CCD imagers for the S1 IS & the S2 IS, unfortunately only the S1 is on the service advisory list. When you send your camera in, make sure you talk to a manager. I did and now I don't have to pay for the repairs even though my camera is out of warranty.
Posted on May 27, 2007
I have the same issue with mine, lcd and viewfinder black and if you take a picture it is black. I talked to Canon and while they are willing to send me a link for free shipping, they will not budge on repair cost and my warranty is up (I've had it for 18 months and use it lightly). No way will I pay $119 for repair when I have seen the S3s for double that. Of course, I will NOT be buying one since Canon admitted there was a problem and then failed to fix the problem in designing the S2s, they just aren't admitting it. The CSR I talked to said this was the first he's heard of it even though a quick internet search brings up plenty of cases of black screen problems.
Posted on Apr 24, 2007
I've owned the camera for about one year and suddenly began experiencing this problem: a blank viewfinder / screen. One temporary fix seems to be to open and close the small door containing the memory card, possibly removing the card. This "restarts" the camera. Why this should work is a mystery to me, but it's only way I can get an image to reappear in the viewfinder.
Posted on Mar 15, 2007
From a similar solved problem: I have read of this problem (doing research before buying a Canon S2). Apparently it is a bad sensor and Canon will fix it for free if it's still under warranty (otherwise it will cost $119.00). and I have the same problem. Just got off the phone with Canon and have to send the camera to them. Repair takes ~2wks. Call them @1-800-828-4040 and follow the menus. Canon's site also addresses this for the S1 and others (but not the S2). Says heat and high humity can cause a connection to the sensor to come undone. Hope this helps.
Posted on Jan 06, 2007
We took one apart... if you want to see what the connectors look like inside. http://www.rainydaymagazine.com/RDM2007/RDMHomeJun2007.htm#S2Disassembly
Posted on Jun 28, 2007
SOURCE:
MY CANON G10 DOES NOT SHOW AN IMAGE ON THE SCREEN ON THE BACK OF THE CAMERA?
Known issue!
G10 => Dead Black Sceen ! (only on screen infos): Canon PowerShot ...
https://www.dpreview.com/forums/thread/2639340
  1. Cached
Aug 13, 2009 - 11 posts - ‎4 authors My G10 is dead a few days ago, in a middle of a trip... (can't explain my ... Does the camera take pictures and can you download them to your computer? Then your sensor is OK and ... No cover on lens, and tried every display mode, you can trust me. ... (and even on, I will not have a permanent black screen). PowerShots can't do purple!?: Canon PowerShot Talk Forum ... 29 Dec 2013 G11 Date & Time Issue: Canon PowerShot Talk Forum: Digital ... 31 Jan 2010 G10's LCD dims when held in vertical position: Canon PowerShot ... 16 Nov 2008 G10 Can we adjust in camera parameters like sharpness for JPG ... 16 Nov 2008 More results from www.dpreview.com
A Simple Fix for a Stuck Shutter 'Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
  1. Cached
  2. Similar
May 30, 2009 - Would not recommend trying to open your cameras to repair this ... Also turn off the LCD screen (press the DISP or DISPLAY button). ... For many Canon cameras this will be shutter priority (Tv) mode (for .... I got the image back in about 5 tries. .... My Cannon S2 IS had a black picture and I fixed it from your ...
Canon G10 screen is black
www.lionebra.com/canon...g10_digital_camera/q1947687-canon_g10_screen_black
  1. Cached
Canon PowerShot G10 Digital Camera - Canon G10 screen is black- ... with the menu,changed something and now the screen does not show image of anything. ... has problem in CCD Imager and this part will be replaced to get back picture. ... E18 my canon powershot A150, got the whole E18 problem, it turns on with the ...
Canon Powershot G10 image quality problems... I have had my Canon ...
www.lionebra.com/canon...g10...camera/q4217842-canon_powershot_g10_image_q...
  1. Cached
Canon PowerShot G10 Digital Camera - Canon Powershot G10 image quality ... They are not coming back with a completely blank screen as I can see the ...
Digital camera repair - Digicamhelp
www.digicamhelp.com > Digital camera care > Digital camera repair
  1. Cached
  2. Similar
Digital camera repairs can be expensive if not covered under warranty or a service advisory. ... When a sensor goes bad, images may exhibit some or all of the following: ... Hard reset for Canon compact cameras: this has worked for some Canon ... a blank LCD screen, a stuck lens or sensor or other problem that can't be ...
S2 IS "black screen *****" problem: a SOLUTION! ' Canon PowerShot ...
https://www.flickr.com/groups/26928900@N00/discuss/72157606903408401/
  1. Cached
  2. Similar
Aug 23, 2008 - My 1st Canon (film) camera was a TL and I'd probably still have it but ... The "change the batteries" problem: Does any S2IS *not* have the ... A couple of weeks ago i turned on my dear S2 IS and.. no image!! i could only see the menus .... Actually, I had to do it 3 times before the screen got back the image.
Nov 24, 2016 | Canon PowerShot G10 Digital Camera
Canon pc1130
Press display (DISP.) button to turn the display on. This button is located on the rear of the camera and toggles the camera's LCD display. The button is usually printed with <DISP.> on the button or above the button depending on the model. display_button.gif If pressing the <DISP.> button doesn't turn the display on, remove and replace the batteries in the camera. If this still doesn't correct the issue, the camera may need to be evaluated by the Factory Service Center.
Ref: http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_s_series/powershot_s2_is#BrochuresAndManuals
Ref: http://kbsupport.cusa.canon.com/system/selfservice.controller?CONFIGURATION=1011&PARTITION_ID=1&secureFlag=false&TIMEZONE_OFFSET=&CMD=VIEW_ARTICLE&ARTICLE_ID=5359
Dec 18, 2012 | Canon PowerShot S2 IS Digital Camera
Image cant see an image in camera or on lcd moniter
Press the DISP button to toggle through modes, which includes the LCD screen
Jan 16, 2011 | Canon PowerShot S2 IS Digital Camera
My Canon S2 IS Powershot camera LCD screen turned black
A stuck shutter is another common failure mode for digital cameras, ESPECIALLY for the S2 IS (you should actually complain to Canon at 1-800-OK-CANON. If it is indeed a sticky shutter, they have been fixing this for free). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Hope this saved you $99.
Apr 29, 2010 | Canon PowerShot S2 IS Digital Camera
CANON pOWESHOT S1 : BLACK SCREEN WITH PURPLE LINES ( BOTH SCREEN)
Yes they will. If you are still living in Canada, or in USA, call 1-800-OK-CANON to arrange free repair.
Mar 28, 2010 | Canon PowerShot S2 IS Digital Camera
The camera won't register an image to take a picture of.
LCD monitor electric film contacts must be fixed. If you can not do it yourself then please contact with the nearest authorized Canon Service. I think it is too easy to fix it so it is not need much money.
Feb 28, 2010 | Canon PowerShot S2 IS Digital Camera
Camera's screen is black, but still takes pictures.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, try pressing the DISP button once with the camera turned on.
Dec 18, 2009 | Canon PowerShot SD1100 IS Digital Camera
I have no image in the viewfinder on a canon S2 IS but the lcd display works and it seems to work fine otherwise. What are the likely causes?
There is sometimes a button on digital cameras that turns off the LCD while taking pictures to save battery. Does your camera have a viewfinder? If it does then there might be a button that looks like a little screen or says "disp" or something like that.
Jun 12, 2009 | Canon PowerShot S2 IS Digital Camera
Can t see pic saved on the card on the lcd screen
Did you accidentallypress the DISP button on the back of the camera? Try pressing it to see if it turns the display back on.
Jan 25, 2009 | Canon PowerShot S2 IS Digital Camera
Canon S2 problems
Low battery power ? (rechargeables do not last forever).
Try a brand new set of batteries
Feb 06, 2008 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
373 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
