Question about Miele Dryers
I have a Miele De Luxe - electronic T 380 dryer. When you press 'on' -- you just hear the clicking, just like you do when it's starting -- but the drum doesn't turn & the clothes don't dry. The light goes on as if it's working. When I turned it on last night & went to check on the clothes after an hour (I thought it was working) they were all wet -- the inside of the dryer was really hot though! We've never had a problem since we bought it (in 1990?) Please let me know how I can go about fixing it. Thanks, Carol cmelo5@sympatico.ca
  • 89 Answers
It seems like your dryer is jammed mechanically,it happens due to dwmwged water seal.
check them up.
try rotating your dryer manually with hand,.
clean and lubricate it.
Posted on Nov 03, 2008
    Genius:
  • 1,122 Answers
SOUNDS LIKE OVER TIME THE BELT HAS WORN AND BROKE,WHATS YOUR MODEL NUMBER>MOST ARE INSIDE THE DRYER DOOR-MIKE
    President:
  • 2,712 Answers
Looks like you will have to get the motor checked/replaced as it doesnt seem to be working.
    Brigadier General:
  • 3,614 Answers
Here is what to do:
1) Check and clean the lint trap.
2) Be sure the dryer isn't pushed so close to the wall that it pinches off the airflow through the vent's air duct hose.
3) Check the point where the air duct vents away from the house. Be sure plants, birds, or other objects have not blocked it. If the duct vents out the roof, it could easily be blocked with lint.
4) Disconnect the air duct hose from the back of the gas dryer, and clean out built-up lint. Note: For safety, first turn off the gas to the dryer, and then unplug the dryer; this means you will have to relight the pilot light later if the dryer has one (read your owners manual for proper relighting techniques).
5) If necessary, clean out the ductwork from the dryer to the exterior wall where it vents; this may involve disconnecting sections. One trick that sometimes makes this job easier (but only if the dryer duct is fastened firmly at all connection points) is to blow lint and debris through the duct and out the exterior wall vent, using an electric leaf blower.
Why the slow blow fuse in miele t9800 lt is burnin ?
because your vent is probably clogged up
Feb 01, 2015 | Miele Dryers
My miele t1430 dryer wont start when I press start there is one click and thd door opens
Seriously i'm not being funny, but are not pushing the door open button
Sep 18, 2014 | Dryers
DRYER STOPS/STARTS DOESN'T GET HOT ENOUGH
dryer duct blockage caused thermal limiters to trip. four t 20 screws remove the heater bank cover on the back of the dryer. unplug the dryer. unplug the dryer. did i forget to mention, unplug the dryer? remove the heater bank cover, and press the three red buttons in the center of each thermal limiter. at least one of them should click when you press it. replace the cover, plug the dryer in. it will now heat, but if you dont fix the blockage it will trip again.
Jun 14, 2012 | Miele T9800 Electric Dryer
We have a Hoover Elecron Dryer De Luxe D6292 and the drum will not turn. There is a loud clang and the belt is no longer on the pulley arms. We have tried replacing the belt, but each time the drum rotates...
here is a picture of some belt diagrams:
http://www.applianceaid.com/images/belt-config.JPG
Now there may be a problem with the drum rollers/glides or idler arm:
rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
idler pulley(third on list right under motor):
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Hope this helped Tim
Jan 09, 2011 | Dryers
Our Miele dryer gives a clicking sound each turn of the drum. But when in hold mode: pausing, reversing, then rotating -- there's no clicking sound. Is this normal, or time to call a Miele repair person?...
Hello & Welcome to FixYa
The clicking sound that you hear can be caused either by the timer going bad or the electronic board itself has gone bad. As the dryer works when in hold mode the problem can be with door switch or the motor relay. There are some tests involved that should be done in order to verify which part has gone bad, so you know its always better to get this checked by a tech. so to avoid any add on charges. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Miele T9820 Gas Dryer
Dryer won't start
Jon
Some dryers now come with a lot of electronics to run them and with electronics and heat, they don't like each other.
The click you hear is a relay switch on a board inside on or near a power board simular to a tiny computer,
Rplace that board.
Now to know which board is another question,
With the power removed (unplugged) disassemble the top part or the back of the dryer. When inside follow the main wires from the plug and see if it meets a electronic board. It could be or maybe burnt.That is you main power board, take it to an appliance shop to replace it
Take along your model# of your dryer
Happy drying
Jul 25, 2010 | Samsung DV306LGW Dryer
Kenmore he2 electric dryer
The lent sensor is either dirty or is bad. It could also be the control board that is faulty as well. Unless you know electronics and have the proper testing tools, I would recommend calling a service professional. Hope this helps and that you have a fantastic weekend.
Apr 11, 2009 | Kenmore Dryers
Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Oct 14, 2007 | Miele Novotronic T220 Electric Dryer
Keeps stopping
sounds like your mains filter which is situated next to your motor most dryer mains filters are the same easy to replace just undo back of dryer and you will see it at the bottom left hand of your dryer 1 14ml nut to undo to change it m8
Apr 01, 2007 | Miele T250C Electric Dryer
Dryers Logo
48 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
