Home | Panasonic | DMR-E85H DVD Recorder | Can't change the clo...
Panasonic DMR-E85H DVD Recorder
Problem for Panasonic DMR-E85H DVD Recorder
Can't change the clock time
By dmcclannahan on Nov 03, 2008
I have a DMR-E85H DVD Recorder. I am trying to change the time clock to read the new time since we are now on Standard time again. I can get to the selection screen which gives me either Auto clock set or Manual clock set. When I try to select Manual clock set, it will not let me go any further. Auto clock set will also not go any further. I have powered down the unit and unpluged it and everything else works but it will not let me change the clock time.
Best Solution
posted on Nov 06, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem. I finally reset the unit to its factory defaults. From the avsforum.com (quote)
"With power off (stand-by mode), Press and hold [skip reverse |<< ] [Time Slip] [Open/Close] buttons on the unit's front for about 10 sec. Unit will go into Self Check Mode and then Display 'L1 TEST'. Now power off. Clock should be flashing 12:00. Turn power on and intial setup menu will be displayed on TV. Use also for DMRE50, DMRE55 AND DMRE85 models also."
I was then able to manually set the clock (and disable DST mode).
Solution #2
posted on Jun 17, 2009
Very Helpful)
dbax521
Rank: Guide
Rating: 100%, 1 votes
Best Solution posted Nov 6, 2008, by Guest -- worked for me. Wondering what the DST is? -- Daylight Savings Time. There will be a button at the bottom right in the date OFF. Apparently the TV Guide programing does not work that well, especially with the new Digital boxes now need to receive over the air TV and the TV Guide programing never worked with Satellite TV. Wil this feature ever be up dated? I doubt it. It would be nice to have the digital box and your dvr cycled together.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Panasonic DMR-E85H DVD
Questions and Unsolved Problems for Panasonic DMR-E85H DVD
Do you recommend Panasonic DMR-E85H DVD Recorder?
Answer
Answer
tvguide service does not work on panasonic dmr=e85h even after redo setup.
Answer
I've replaced the 2 capacitors that was causing the "Please Wait" message to hang. Now the... (More)
Answer
When plugged in, the display just says "PLEAS WAIT" constantly.
Answer
No sound, tried replacing rca cables and coaxial. Turned off to reboot, no luck.
Answer
my unit just says "please wait" on the screen. It will not let me do anything or boot up.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic DMR-E85H DVD...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
