Do you have the PTA02 accessory for the TV? This is a USB 3D transmitter and comes with 2 pairs of Active 3D glasses. The screen of the 40PFL8605H is not a 3D TV by itself.
Once you have the accessory plugged in, you may need to wait for the software to be installed on your TV before you can watch 3D content. See the manual for the TV for more information:
http://download.p4c.philips.com/files/4/40pfl8605h_12/40pfl8605h_12_dfu_eng.pdf . This is on page 73 of the PDF.
I hope this helps. If you have the 3D accessory plugged in, try turning off the TV and turning it back on if the software did not install properly. The final thing to check is the "codecs" for your 3D movies on the USB stick. Make sure that they are compatible with the TV.
Got a double picture when it's damp out! Eyes are in the forehead, mouth on the nose ect ect....
My picture appears to be 3-D, seems like the 3 tubes may be out of alignment. The word Encore in the bottom right of my screen appears 3 times, 1 red 1 green 1 blue. And the menu is the same way. When i pull up my comcast info bar it is now rounded instead of being in a straight line. Is there an easy way to fix this or do i need to call a shop?
My TV is also not this exact model but there were no listings for mine.
RCA HDTV model # R56WH78
