Question about HP LaserJet 5200tn Printer
PROBLEM WITH PRINTING
My printer is not responding, it keeps showing 50.4 FUSER ERROR. Somebody please help me out.
  • Abdulrazaq Adio Nov 04, 2008
    thanks a lot, it suddenly started workin again will try out your solution next time it happens again cos i have a history of such malfunction
  • 47 Answers
You have problem with your fuser in printer, as the message says. Having the powercord straight to wallsocket, no extensioncables? Try take it out and reinsert if it's removable. otherwise you have to buy a new fuser.
Posted on Nov 03, 2008
I keep getting a 50.2 fuser error. Turned off
wheb i give the print out, just show error 50.2 fuser error,
pls give me solution what may problems
May 02, 2010 | HP LaserJet 2840 All-In-One Printer
Will not print.
LaserJet 4V ***If it is intermittent or can be cleared by shutting it off to let it cool. The fuser is running too hot, order rebuilt.***
Notes to remember!!
  • The low voltage power supply is what the takes the 110v ac from the outlet and is for this reason often mistaken as the high voltage power supply. The high voltage power supply HVPS main purpose is to charge the toner cartridge with a much higher dc voltage.
  • Always Remove Power from the printer before working on it!
  • Lamps can break in shipping or if the fuser is dropped.
  • The fusers use floating connectors don't force them in.
Jun 25, 2008 | HP LaserJet 4mv Printer
HP Color LaserJet 2840 keeps showing 50.2 Fuser error message. Nothing helps correct problem. What to do? Have tried repeatedly turning printer off, waiting several seconds and turning on again. Each time...
The fuser is the heating unit near the paper exit, and that error means the lamp is burned out, the overtemp sensor is out, or the thermistor in the fuser is bad. About all you can do is replace the fuser. www.precisionroller.com will have a new fuser for you.
Jan 12, 2010 | HP LaserJet 2840 All-In-One Printer
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
Kyocera FS-1020D lights blinking but doesn't respond
Fuser error (6000 error)
Contact your Kyocera Mita dealer.
Unfortunatly there is not much You could do Yourself
This error means that the fuser is either damaged or not connected properly to the rest of the printer. If its connection error You could try to fix it but in most cacses the fuser is just broken ie. overheated due to not enough air flow.
May 28, 2009 | Kyocera Mita FS-1020D Laser Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
Cannot reset code 50 for service
50 error is the fusing assm. You need to replace the fuser then the error will go away.
hope this helps.
Mar 23, 2009 | HP LaserJet 4 plus Printer
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
50 service flashing on display screen
If the display panel reads 50 FUSER ERROR, CYCLE POWER, turn the printer off for 15 minutes. This allows the capacitor that is responsible for signaling this error to discharge. If you don't wait 15 minutes you will continue to get this error even if you have replaced the fuser. If it continues to show the error, then you need to replace the fuser. It is easy to replace.
The fuser maintenance kit is about $119. on the web.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | HP LaserJet 4 plus Printer
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
HP LaserJet 5200tn Printer Logo
98 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
