Epson Stylus Photo R220 InkJet Printer Logo
Anonymous Posted on Nov 03, 2008
Epson R220 not printing
I have the above printer,i've cleaned the ink pads and also used ssc utility.
The problem is it goes through all the actions but no ink on paper,i've tried two new sets of ink with no joy.
The red lights do not come on showing any errors.
Can someone please help if you have had the same problem.
Cheers
Alan
Inky Fingers
Level 3:
  • Epson Master 705 Answers
  • Posted on Nov 09, 2008
Inky Fingers
Epson Master
Level 3:
Answers
705
Questions
0
Helped
433755
Points
1443
Sounds like you knocked the vacuum pipe off at the pump cap when you had it apart. Take it apart again and check the vacuum pipe for connection, blockages and being trapped between cases when you reassembled it.
How can reset epson artisan 730 using ssc service4.30 in winddows 7/8
Download WIC Reset Utility - Free - 2Manuals.com
www.2manuals.com > ... > WIC_RESET
Operation Systems: Windows XP, Windows 7, 8, 10, Mac OS ... THE WIC ResetUtility WILL RESET Your Epson Inkjet Printers WASTE INK COUNTERS ... 700, Artisan 710, Artisan 720, Artisan 725, Artisan 730, Artisan 800, Artisan 810, Artisan 830, .... Q.: If I buy 5 RESET KEYs I can use them for different printer models?
WIC Reset Utility - Reset Epson printers Waste ink Counters
wic-reset-utility.blogspot.com/
Oct 5, 2014 - Artisan 720.725\Artisan 730\Artisan 800\Artisan 810\Artisan 830 .... If I buy 5 Reset Keys CAN I use them for different printer models? .... The Windows 7 WICReset Utility - for Waste Ink Pad Counter reset - Service ... Reset epson printer protection counter using ssc service utility, reseter epson r220 [...]
Printer Manual: SSC Service Utility for Epson Stylus Printers
printermanua.blogspot.com/2014/.../ssc-service-utility-for-epson-stylus.h...
Feb 22, 2014 - Problems with Epson printer, the red and greenness lightheaded ...
How to reset waste ink pad on Epson photo printer R220
There is some utility available on Google to reset the printer ink. but its depend which model you are using. "search like R220 ink resetter utility' hopefully it will work for you or goto service center for its repair may be its cost is approx. Rs 350/-
Where can I get ssc service utility for Epson Stylus sx 105?Thanks
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
4helpful
How do you change or clean the Epson R220 waste ink pad, are there photos or diagrams on how to do this? Thanks.
you need to download adjustment program of this printer of you can download "SSC Service program " by searching google.
you need to reset protection counter.
Sk Abdus Sabur
2answers
Parts inside your printer are near the end of their service life
Hi and welcome to FixYa,
A possible workaround to "end of life" on Epson printers; download, install and run "SSC Service Utility"
Good luck and thank you for asking FixYa.
1helpful
Epson R220 won't print. Paper feeds through OK, print head moves as if printing but no ink comes out. Tried several sets of cartridges and this makes no difference. Cartridges are recognised fine and no...
Nothing at all? Problem with micropiezo (micro pump) at head. But you said, replaced print head. So it might just lost electricity to head (problem with board).
2helpful
Both red light keep blinking
You need to reset waste ink counter. Use SSC Utility or R220/R230 Adjusment program. Find the software at indoreset.blogspot.com.
2helpful
2answers
Green and red light flashing
SSC Service Utility allows you to do many things to your Epson printer, Work directly with CSIC in Epson Stylus printers cartridges, Freeze internal ink counters, Reset internal ink counters even with empty cartridges, Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode, Hot swapping of cartridges supported, Resetting of protection counter (even then it is already full), More then 60 different Epson printers supported This allows many people with high printing demands to save money (program works with both black and color cartridges).
APPARENTLY EPSON DETERMINES THE PRINTING LIFE OF IT'S PRINTERS AND SCHEDULES THE SHUT DOWN OF THE PRINTERS. HOW CAN I OVERCOME THIS PROGRAMMING?
If you mean the "parts in the printer have reached the end of their service life" or "Service required" then you need to do two things.
1. Reset the waste ink or "protection counter" in your printer.
This requires the SSC utility (for the R220) printer.
2. You need to redirect your waste ink flow to an external tank of some description or replace the waste ink pads in the printer. The external tank is a lot easier to do...
Help on this is available here
Printer says "ink is out" when I try to print but it's not
this mean your printer waste pad maybe full and the printer needss to be reset download the ssc and it will reset it for you
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
