Question about HP DeskJet 460WF Mobile Color Printer
Blurred bands in prints
My HP Deskjet 460 has been used very little even though it is over a year old (50 pages printed). When printing horizontal pages there are evenly spaced blurred areas in the text, approximately 1 inch apart. Upon close inspection it appears that the letters are being printed more than once, very close to each other, causing a general blurry effect. This also happens in verticle layouts, but to a much less degree. The text between these bands is sharp. I have cleaned the print cartridges, and the contacts. I have also alligned the print heads. My best guess is that it might be a paper feed problem--it happens with various types of paper--since it appears that the paper must be moving ahead in order to cause the double image effect. HP has not been able to suggest a fix. Thanks for any help you can offer.
  • HP Master
  • 218 Answers
Try changing ink cartridge. Print only "grayscale" and if that happens, you need a black cartridge changed. If, not color
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Posted on Jun 17, 2017
5 Suggested Answers
michael464
  • 8 Answers
SOURCE: Incompatible ink cartridge(s) ERROR on HP 4230 All-in-on printer
Try uninstalling and reinstalling the drivers. This can be done by going to the Add and Remove programs, this is located under the Control Panel. You may have to reboot and I would recommend that you do. This will clear out the Print Spooler. The Print Spooler is located under the C Drive and may get corrupted. You can find information about this in Google. Look for repairing spooler on the OS that you are using.
Posted on Dec 31, 2008
  • 88 Answers
SOURCE: printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Posted on Mar 20, 2009
  • 81 Answers
SOURCE: The Color is printing blurred?
Could be down to dirt contamination in the laser scanner
Posted on Oct 12, 2009
  • 217 Answers
SOURCE: hp color laserjet 1600 copies have a blurred image
This sounds like a registration problem.
Use the menu (on the printer) to print antest page AND a configuration/information page.
Look (critically) at the alignment of the seperate coloure Yellow Magenta Cyan. You will probably find that these are out of aligmnent across the page.
The cause of this, is that the printer can't perform a calibration properly (printer probably takes a long time when calibrating too) and is usually down to failure of one of the sensors on the transfer belt.
Sometimes you can clean these and solve the problem, but often is a failure of the component itself. Thes are NOT available as a spare part, and the repair to correct this would need a replacement transfer belt.
Transfer belt replacement in this printer is quite an involved task, though it is within the capabilities of someone with reasonable mechanical aptitude.
Posted on Apr 05, 2010
HP CP1215 Printing is blurred
should of included a pic of print.
Blurred prints are usually fuser related.
Nov 15, 2016 | HP LaserJet CP1215 Color Printer
Horizontal lines on page
Your printer head - the ink cartridge in case of most HP deskjet printes, in most cases is defective and you need to replace it to have a clean print.
Anyway, read this tutorial, has some good tips:
HP Deskjet D2500 Printer Series Horizontal Streaks or Lines in the Printed...
For Epson printers, read this
Epson Stylus Color Ink Jet Printer
Epson Printer Horizontal lines
Same for Cannon priters
Horizontal lines when printing with Canon ip4500 Forum Thread
Aug 23, 2015 | Office Equipment & Supplies
Printer won't print color
when you go to print something, the screen comes up with the print instructions
no of copies
print all print pages etc
there you will find a properties tab
click on that and it takes you to paper size next tab is black & white or color click on color and then down the bottom click on default
as to problems with hp printers , I use a hp deskjet 2050 series now over 9 years old and still capable of printing out manuals up to 1000 pages long so makes me wonder if you are expecting too much from your printers and why with so much dissatisfaction with a product, you still persist in buying the brand
Apr 30, 2017 | HP Deskjet 3520 e-All-in-One CX056AB1H
My HP Deskjet 5650 will not print in color even though i have installed a new cartridge yet the test page is in color??
Just check your printing property and choose color print and apply the settings and then ok.
Good Luck
Feb 26, 2011 | HP DeskJet 5650 InkJet Printer
Color cartridge runs out even though I'm only printing b&w typed scripts. Any way to shut it off? Only have use for color printing once in a blue moon Hewlett Packard HP DeskJet Printer #932C
Even though you print a b/w document... unless you say 'black cartridge only' in your printing preferences, all the colors get used.
Find 'black cartridge only' in your printing preferences, or 'print in greyscale' and then print your document. You must specify this for your printer to know that it must use the black only.
Jul 23, 2010 | HP DeskJet 932c InkJet Printer
When I first print a page of text, it comes out all faded--like when the cartridge is empty, even though I just had the cartridge refilled. When I print the same page again, the text becomes a little...
Ok two things here, the slides need wiping with a cloth, even use a small amount of sewing machine oil on cloth ( SMALL AMOUNT I SAID) then run the machine in cleaning mode and also check the print mode this is in the printer queue module under tools or maintenace.
Jun 20, 2009 | HP DeskJet 845c Printer
HP Laserjet smudges across entire page
More than likely you have a bad toner cartridge.
Inkworks
866-381-0541
Nov 03, 2008 | HP DeskJet 5650 InkJet Printer
Horizontal white lines through the text
Your ink cartridge (s) is dried up, even some new ones are dried up, even tho' they're sealed.
Some self-tests don't use black.
Sep 21, 2008 | HP DeskJet 6122 InkJet Printer
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
Slow and blank printing
sounds like clogged print heads. do a clean print heads, then a test page, and see how that goes. Like a sink that gets clogged, when it's not used, print heads need exercise, otherwise, they can get some gunk on them, and no more printing.
Feb 06, 2008 | HP DeskJet 5150 InkJet Printer
HP DeskJet 460WF Mobile Color Printer  Logo
97 people viewed this question
Clive
Clive
